LGTMAN Posted December 20, 2014 Share Posted December 20, 2014 I finally got my leggy back after a deer accident(month later). So I started with the little mods that matter. I started by replacing every single interior bulb with LED's. When finished I wasn't happy with the amount of light coming from my map lights. So I took it to myself to do something about it. It was super easy, -Started by taking off the light cover. -Once removed you will notice that the clear piece separates from the grey piece that has the little square openings. -Turned the squares into rectangles, And check it out http://tapatalk.imageshack.com/v2/14/12/19/a8abdb48dd0f1efaab103cb295284e79.jpg Link to comment Share on other sites More sharing options...
LGTMAN Posted December 20, 2014 Author Share Posted December 20, 2014 http://tapatalk.imageshack.com/v2/14/12/19/eee8f7b2c67af87b0156446253b05de0.jpg Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted December 20, 2014 Share Posted December 20, 2014 Nice, looks like I'll be doing this mod as well. I put in led's months ago and haven't been happy at all. 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
LGTMAN Posted December 20, 2014 Author Share Posted December 20, 2014 Same here, I was really disappointed for about 5 min. then I got to cutting. If you drill holes as an outline you then only have to shave off a little bit to make it a straight cut. Link to comment Share on other sites More sharing options...
xtea Posted December 20, 2014 Share Posted December 20, 2014 How did the LED install go? Was it plug and play? Link to comment Share on other sites More sharing options...
LGTMAN Posted December 20, 2014 Author Share Posted December 20, 2014 How did the LED install go? Was it plug and play? Plug and play straight from ebay! Can't beat it, I got 10 for $5. They work great so far, if one goes out I have 2 spares for each light. . Smart thing to do is pull a bulb out when you order them and know the length so you can order the correct ones. I also did my license plate and trunk.(diffrent size and type than map and doors) Link to comment Share on other sites More sharing options...
AF_3C2 Posted December 20, 2014 Share Posted December 20, 2014 I did the LED change out- looked a hell of a lot better over stock to me. May need to look into this map light thing.... Link to comment Share on other sites More sharing options...
