pulzar Posted December 19, 2014 Share Posted December 19, 2014 Installed a transmission but leaking from banjo bolt. Is it possible to tighten up without removing trans???? Link to comment Share on other sites More sharing options...
Osei Posted December 22, 2014 Share Posted December 22, 2014 If you are referring to the large bolt for the input, yes. You should remove and make sure the seat area is clean. Don't lose the spring and make sure both sides of the crush washer are clean also O. Link to comment Share on other sites More sharing options...
