oppamen Posted December 17, 2014 Share Posted December 17, 2014 I went to discount tire because my toms light keeps coming on. They told me I had to replace my wheel because the part where my tire and wheel touch are getting corroded. I saw it but I don't see any rust. Just black marks from tire. Your suggestion would help me. Can I get it cleaned off? They said they tried cleaning it as much. Link to comment Share on other sites More sharing options...
bluesuby Posted December 17, 2014 Share Posted December 17, 2014 I would think there has to be a hell of corrosion problem. I'd try sanding with a dremel and painting over the spot. Maybe they mounted a very cold inflexible tire? I've heard a nitrogen fill will stabilize pressure better than air. Link to comment Share on other sites More sharing options...
starionesir Posted December 17, 2014 Share Posted December 17, 2014 Did they show you the inside of the rim where the bead seats? I have seen many rims that had leaks because of moisture causing rust. Sometimes they can be sanded down and sometimes they can't. That is the big selling point of nitrogen is no moisture to cause corrosion to the rims or the tpms sensors. Link to comment Share on other sites More sharing options...
outahere Posted December 18, 2014 Share Posted December 18, 2014 Is this a steel wheel or an alloy wheel? Link to comment Share on other sites More sharing options...
