LegacyCamper Posted December 14, 2014 Share Posted December 14, 2014 I have a BG chassis. Its lowered and we want to use it for towing and light farm crossings. I want to put in outback struts which I have already sourced at a good price as I read this is a straight swap. Is there an instructional web page or youtube on how to do it, I dont have a manual. I presume I need to hire a torque wrench and will need some wheel ramps. It should take from 4" to 9". Legacy should have been 6" but this legacy is slammed. Link to comment Share on other sites More sharing options...
98legwag Posted December 16, 2014 Share Posted December 16, 2014 Jack the car up and put it on jack stands and take the wheels off. Break the lug nuts loose while its still on the ground. The front struts will have three bolts holding them in at the top in the engine bay and two bolts to the knuckle. One is a camber bolt so mark the setting so you can get it close when putting the new parts on. The rears are pretty much the same just no camber bolts. The three top bolts in the rear are in the hatch area under a plastic cover. Its pretty straight forward. Link to comment Share on other sites More sharing options...
LegacyCamper Posted December 24, 2014 Author Share Posted December 24, 2014 Thanks that does look like something I can do. There is much conjecture on the net about spacers. if Im swapping with the same year ourback struts and springs, do I need spacers? Link to comment Share on other sites More sharing options...
98legwag Posted December 24, 2014 Share Posted December 24, 2014 You shouldn't need them unless you want to go above stock height. Link to comment Share on other sites More sharing options...
