the pizza Posted December 14, 2014 Share Posted December 14, 2014 Just curious if anybody else's legacy gt sometimes stalls every time you stop, out of nowhere. It just kind of does this from time to time for me. Don't understand it? might just be the ghost in the machine I guess...lol. Link to comment Share on other sites More sharing options...
MrTris Posted December 14, 2014 Share Posted December 14, 2014 Injectors or OCVs tend to solve this issue. New OCVs are always a good idea, especially if they're the original ones and you're over 75k. New injector cost a pretty penny -- bit over $100 for new oem. But deutsch works or Witch hunter can clean them for about $20 apiece. Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 15, 2014 Share Posted December 15, 2014 Front O2 sensor. Bad front O2 doesn't necessarily set a CEL either. When they go bad, it causes STFT to go all over the place and can make it surge up and down or drop like you described. Find a good one to borrow and try the car again and I would bet that it fixes the issues. Link to comment Share on other sites More sharing options...
Akasa Posted December 15, 2014 Share Posted December 15, 2014 Could be a vac leak? I've had vac leaks that cause crappy idle and stalling issues. If it only does it when it's cold, it could be your intake manifold gaskets. There's honestly a lot of things that it could be, any guess could be it. MrTris, what are some of the symptoms of an OCV valve needing replacement, besides the obvious codes? (Not to hijack a thread of anything.) Link to comment Share on other sites More sharing options...
the pizza Posted December 16, 2014 Author Share Posted December 16, 2014 Thanks for the advice yall! I'm thinking its either the OCV or the front o2 sensor. I think my injectors should be decent cause I sent them off to witch hunter last year and had them cleaned. As for the manifold gaskets during winter, I think I'm alright cause its been colder than it has been this past week, so far this year, and it did just fine before that. Again, much thanks for the knowledge yall. Link to comment Share on other sites More sharing options...
