highwind Posted December 8, 2014 Share Posted December 8, 2014 i have a 09 legacy and im trying to find out the location for the model number plate but i cant find it. i need to know so i can order the the right parts from japan. thanks Link to comment Share on other sites More sharing options...
Redslaya Posted December 8, 2014 Share Posted December 8, 2014 Open your hood, right by the drivers side tophat by the wheel well Link to comment Share on other sites More sharing options...
highwind Posted December 8, 2014 Author Share Posted December 8, 2014 i looked an couldnt see anything. would it be covered up by something or should it be easily visible? Link to comment Share on other sites More sharing options...
apexi Posted December 8, 2014 Share Posted December 8, 2014 As redslaya said the VIN is engraved in the firewall. If you open the driver side door, there is also a label there on the lower side of the door with the VIN number and build date of the car. I'm glad you asked actually, because I was looking for the GVWR and GAWR ratings for our cars the other day, and couldn't find the label anywhere. I'm not sure if that's what you mean by model plate, but that's the closest I got. Link to comment Share on other sites More sharing options...
Redslaya Posted December 8, 2014 Share Posted December 8, 2014 Here is where it is in my 06LGT http://i.imgur.com/aX8Gq9d.jpg?1 http://i.imgur.com/1IITedf.jpg?1 http://i.imgur.com/zAvIkHb.jpg?1 Link to comment Share on other sites More sharing options...
apexi Posted December 8, 2014 Share Posted December 8, 2014 Interesting, my 09 doesn't have that, thanks for the pics. I almost edited my last post because I didn't want to put words into your mouth. On my 09 the vin is engraved on the firewall near the passenger side strut. Link to comment Share on other sites More sharing options...
Redslaya Posted December 8, 2014 Share Posted December 8, 2014 Just so you know though, 4th gen sedans are BL9 while wagons are BP9 the 2.5GT's engine is ej255, the NA i believe is a ej253 (not sure on that) and the 3.0 is called the EZ30 Edit: keep in mind japan's model year system is different. a 2005 legacy in the USDM is a 2004 in the JDM. Link to comment Share on other sites More sharing options...
highwind Posted December 8, 2014 Author Share Posted December 8, 2014 so if the 09s dont have that plate how do i look for parts that will fit my car? im trying to find different a front bumper which has started my quest for the model plate number. Link to comment Share on other sites More sharing options...
Redslaya Posted December 8, 2014 Share Posted December 8, 2014 if you look above you can see where i posted the sedan and wagon model numbers as well as engine codes Link to comment Share on other sites More sharing options...
Redslaya Posted December 8, 2014 Share Posted December 8, 2014 So to sum it up based off your user profile info. you have a BL9 applied E the applied means year, or revisions. so the 2005 is A, 2006 Is B, 2007 is C, etc etc Link to comment Share on other sites More sharing options...
apexi Posted December 8, 2014 Share Posted December 8, 2014 Passenger door! Odd place, but I guess it works. Link to comment Share on other sites More sharing options...
highwind Posted December 8, 2014 Author Share Posted December 8, 2014 groovy thanks for the info guys Link to comment Share on other sites More sharing options...
rkrenicki Posted December 20, 2014 Share Posted December 20, 2014 What are you looking to buy? US chassis and Japanese chassis are not identical, and we got things a few applied models later than they did. A good example of this is that there was no Applied Model F in the US. Your Applied model code says BL9E. This primarily was due to the fact that 4th gen didn't start until 2005 here. Depending on what you are looking for, it may be a year or two off, or will require other parts to work. Link to comment Share on other sites More sharing options...
highwind Posted December 22, 2014 Author Share Posted December 22, 2014 im looking for front bumpers currently What are you looking to buy? US chassis and Japanese chassis are not identical, and we got things a few applied models later than they did. A good example of this is that there was no Applied Model F in the US. Your Applied model code says BL9E. This primarily was due to the fact that 4th gen didn't start until 2005 here. Depending on what you are looking for, it may be a year or two off, or will require other parts to work. Link to comment Share on other sites More sharing options...
