garygbnj Posted November 24, 2014 Share Posted November 24, 2014 I hope that some one can help. Stage 2, 181k miles. Only occurs above 60 degrees. Only when I am coming to a stop. thanks gary Link to comment Share on other sites More sharing options...
Max Capacity Posted November 24, 2014 Share Posted November 24, 2014 I assume no CEL ? I'll guess loose battery cables ? Any other simptons ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BoyceWare Posted November 25, 2014 Share Posted November 25, 2014 Have you recently disconnected your battery? If so disconnect it again, press the brakes to fully discharge the system. Reconnect the battery, turn the key on but do not start it. Turn off your ac/heat, let it sit for 10 seconds then fire it up. Idle for 10 minutes without touching the throttle or air. Then test it out. Good luck! Link to comment Share on other sites More sharing options...
garygbnj Posted November 25, 2014 Author Share Posted November 25, 2014 No cel. Battery was not disconnected. Link to comment Share on other sites More sharing options...
BoyceWare Posted November 25, 2014 Share Posted November 25, 2014 If you have 10 minutes to spare try the above. Worth a shot. Link to comment Share on other sites More sharing options...
