Lost windows and power seat
Today my power windows and seat went south. Neither working. I pulled fuse#26 (windows) and fuse looks good. With fuse removed from panel the seat works fine. With fuse in, I can hear a relay click about every 10 seconds or so when car is running. But no seat or windows. Now I'm confused. Where should I check next? Thanks - John
I did. No different unfortunately. I did notice the seat works when the ignition is off. When ignition is on, the seat will move very momentarily when the relay clicks. (if i hold the seat switch and wait for the relay to click the seat will move for an instant) The windows won't do the same.
Thanks for the advice guys. Fixed, most likely a stuck switch. I exercised all the window switches lightly up and down and laterally. Also tugged each doors electrical harness lightly. Put fuse back in and bingo works fine over the last day. I should have tried it after each door separately, but I was too lazy in the rain. Thanks again.
