Tmccurry Posted November 18, 2014 Share Posted November 18, 2014 Forgive me for not searching (I'm at work). Was wondering if someone could hook me up with the part # for the gaskets I need for uppipe install. I think I need passenger side manifold gasket, and gasket for each side of the up pipe? Trying to call dealership on my way home to make sure they can order if needed for gaskets to be here this weekend. Thanks for the help Link to comment Share on other sites More sharing options...
MrTris Posted November 18, 2014 Share Posted November 18, 2014 See my Shopping List, down at the bottom. You want the Grimmspeed gaskets. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 18, 2014 Share Posted November 18, 2014 Most dealers should have them in stock, they are a common replacement item. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
