abarnesDLGT Posted November 17, 2014 Share Posted November 17, 2014 i drove normally the last 2 days and my car seems to be giving off a white whisky smoke from the drivers side of the car….. it looks like the, UP-pipe? is where it is coming from ….( I'm not to familiar with the name of that section of piping) please help! Link to comment Share on other sites More sharing options...
Max Capacity Posted November 17, 2014 Share Posted November 17, 2014 The up pipe is on the passenger side. The turbo is over there. The axle boot may be torn and sending grease on to the exhaust. The other leak over there is the passenger side valve cover rear lower corner. Get a good light and look around that area. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
abarnesDLGT Posted November 18, 2014 Author Share Posted November 18, 2014 Then I guess u used the wrong name . It Is on the driver side and it comes from that pipe crossing parallel with the bottom of the radiator ..... Exhaust leak? Link to comment Share on other sites More sharing options...
