coop3422 Posted November 17, 2014 Share Posted November 17, 2014 Hey everyone, Just picked up an 07 LGT Spec B on Friday. Love it so far, although my mechanic recommend I get new rear endlinks as the current ones are done. When I had my old 07 WRX, it had more body roll than desired, the Spec B seems similar so I’d like to get some sway bars to help. I found some of a GT on a local form that come with end links so it could be a good chance to remedy this for relatively cheap ($250 for front, rear and endlinks). What I’m wondering is if the ones for an LGT will work with the Spec B suspension without issue? These are what I’m looking at: Whiteline BSF30Z 22mm Adjustable Front Sway Bar Whiteline BSR39Z 20mm Adjustable Rear Sway Bar GroupA Endlinks F&R Thanks! Link to comment Share on other sites More sharing options...
whitetiger Posted November 17, 2014 Share Posted November 17, 2014 yes. the suspension is essentially the same. Link to comment Share on other sites More sharing options...
coop3422 Posted November 17, 2014 Author Share Posted November 17, 2014 Awesome, thanks. The mod bug sure bit early haha. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 18, 2014 Share Posted November 18, 2014 Make sure you get the braces for the rear bushing mounts. See covertrussian's thread in the 4th gen forum. We told him to get them the other day. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
boxkita Posted November 19, 2014 Share Posted November 19, 2014 is the body roll a steady state problem or a lane change problem? makes a difference. Too much bar in the rear makes the car tail happy and hard to control Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
coop3422 Posted November 19, 2014 Author Share Posted November 19, 2014 The body roll hasn't been as bad as my 07 WRX, but I can't say exactly since I've only driven it a few days. Main reason I was looking is to get a bit better handling, and I nbeed to do the rear end links anyways. It's looking like those sways sold before I had a chance so I'll need to keep looking. Thanks Max Capacity, when I find some sways I'll look for the braces. Does it matter what end links I use? Link to comment Share on other sites More sharing options...
boxkita Posted November 19, 2014 Share Posted November 19, 2014 the standard set (flexible) will be a smoother ride. The dogbone solid metal will make for a stiffer ride. For the most part, unless track/autox, swapping sways are not going to have much impact on your day-to-day driving. Just do the end links. When you have driven the car for awhile, then decide to replace the suspension. SpecB has a higher starting point for suspension performance than the LGT, so less is more. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
GTEASER Posted November 19, 2014 Share Posted November 19, 2014 Huh! I didn't know that a Spec B was a different car than a GT. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Stapp's Law: “The universal aptitude for ineptitude makes any human accomplishment an incredible miracle.” "Simple incompetence is a far more sinister force in the world than evil intent." Link to comment Share on other sites More sharing options...
boxkita Posted November 19, 2014 Share Posted November 19, 2014 Huh! I didn't know that a Spec B was a different car than a GT. Really? SpecB comes with Unicorn dust and stickers. While plain LGT just barely gets by. Just look at mod ratio of SpecB to LGT, every LGT on here is modded. SpecB's, rarely. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
covertrussian Posted November 24, 2014 Share Posted November 24, 2014 Make sure you get the braces for the rear bushing mounts. See covertrussian's thread in the 4th gen forum. We told him to get them the other day. This post specifically. Still need to fab up my reinforcements Really? SpecB comes with Unicorn dust and stickers. While plain LGT just barely gets by. Just look at mod ratio of SpecB to LGT, every LGT on here is modded. SpecB's, rarely. That actually explains the 50% mark up on them 05 LGT 16G 14psi 290whp/30mpg 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg Link to comment Share on other sites More sharing options...
