JDM_WAAAAT Posted November 6, 2014 Share Posted November 6, 2014 2008 Spec B. (Diamond Gray Metallic) Purchased in June 2014 with 50,XXX miles. Exterior: AVO grilleMuteki Black Lug Nuts (short)Plastidip grille, fog light covers, rear tail light trimFlat black headlight internalsPlastidip White stock wheels (winter)2014 WRX Wheels (summer)LED Tail lights, Turn signals (Swapped to red turns in rear), and reverse lightsPhilips X-Treme Vision Lows + HighsYellow Fog Lamps Interior: Bluetooth USB to Aux adapterWeathertech Digital fit rear floor mat2 x iOttie Phone holders (one for iPhone 6 and one for Accessport)Flat black A-PillarsFull interior LED lighting by Diode Dynamics Mechanical: Cobb SF intake (black) with airboxCobb V3 AccessportCobb Turbo Heat shieldGo Fast Bits 50/50 BOVInvidia Catted DownpipeInvidia Q300 exhaustGrimmspeed Boost SolenoidPerrin TMIC (black)ACT Clutch SB10-HDSSSTI FlywheelStage 2 Protune from IAG performance To-Do List: XV Crosstrek Wheels + Snow tiresTein Adjustable CoiloversGo wingless or big wing So far, the only pictures I have are before the performance stuff was done. Hopefully will get more pics and videos up soon. When I first got the car: http://i.imgur.com/x5VqxvV.jpg Put the WRX wheels on... http://i.imgur.com/PxueNNL.jpg http://i.imgur.com/khXMR8I.jpg http://i.imgur.com/WReoNTX.jpg http://i.imgur.com/JJV9E3c.jpg http://i.imgur.com/tdvofNt.jpg New Grille and blacked out front end http://i.imgur.com/qFv1aS3.png White-out wheels for winter http://i.imgur.com/jX7vxcL.jpg http://i.imgur.com/yQmpPMj.png Some post-dyno charts - Stage 2 at IAG performance in early November 2014 http://i.imgur.com/SWgyirb.png http://i.imgur.com/U7lYo3x.png November 13, 2014 Replaced transmission mountInstalled Kartboy 6spd Short Throw ShifterGot a Cobb Shift Knob Link to comment Share on other sites More sharing options...
Specbwee Posted November 6, 2014 Share Posted November 6, 2014 Just remember to save some money for when the engine takes a poo. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 6, 2014 Share Posted November 6, 2014 That's a lot of torque for stock fueling. Impressive. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JDM_WAAAAT Posted November 13, 2014 Author Share Posted November 13, 2014 Just went to IAG to get a rattle looked at. Ended up switching back to Subaru Extra S 75w-90 Transmission fluid. Replaced transmission mountInstalled Kartboy 6spd Short Throw ShifterGot a Cobb Shift Knob Link to comment Share on other sites More sharing options...
98legwag Posted November 13, 2014 Share Posted November 13, 2014 Just curious, on the wrx wheels are you running the 235/45/17 stock wrx tire size? Link to comment Share on other sites More sharing options...
JDM_WAAAAT Posted November 14, 2014 Author Share Posted November 14, 2014 Just curious, on the wrx wheels are you running the 235/45/17 stock wrx tire size? Yup, they are the stock tire. I bought the whole set off a guy on Nasioc for $600 with wheels + tires. They are 2014 model year with 8/32 tread. Fit is perfect, and my speedo is only about 2.5% off from stock. 10/10 would recommend. Link to comment Share on other sites More sharing options...
