Power2.5i Posted November 9, 2014 Author Share Posted November 9, 2014 If it is at that connector, then spray some PBB on the connections, let it soak, then tighten each one down and recheck. Thanks a lot for all the help man, I appreciate it! Link to comment Share on other sites More sharing options...
Power2.5i Posted November 9, 2014 Author Share Posted November 9, 2014 Is the fluid coming out of that supposed to be a milky white color? Link to comment Share on other sites More sharing options...
Power2.5i Posted November 10, 2014 Author Share Posted November 10, 2014 Alright so sprayed them and tried tightening them and they are as tight as can be. So you don't think the abs light being on has anything to do with the green and white wire I cut under the dash by accident? Link to comment Share on other sites More sharing options...
SBT Posted November 10, 2014 Share Posted November 10, 2014 Did you repair and isolate the green/white wire under the dash? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
apexi Posted November 10, 2014 Share Posted November 10, 2014 Is the fluid coming out of that supposed to be a milky white color? No, brake fluid looks like brand new motor oil and should be a light amber color (a little darker with age/use), it shouldn't look milky white. I know when motor oil gets contaminated with enough moisture, you will get a milky white film under your oil cap. Brake fluid is highly hygroscopic and readily absorbs any moisture it can get, but I don't think it would ever turn milky white, I could be wrong though. Can you post a picture of the part that's leaking on your car? I'm wondering if for some strange reason your joint connector was coated with anti-corrosion wax. The part I circled in the picture is what subaru coated with anti-corrosion wax as a part of the WQK-47 recall, except the joint connector underneath the car is what was supposed to be coated with anti-corrosion wax, not the connector in the engine bay. I wonder if maybe the technician coated both the joint connector under the car, and in the engine bay? Pictures of connector under car before being coated http://legacygt.com/forums/showpost.php?p=4456614&postcount=23 After being coated as part of the second recall. http://legacygt.com/forums/showpost.php?p=4905645&postcount=20 Covertrussian has better pictures at the bottom of the page below http://legacygt.com/forums/showthread.php/05-09-legacy-outback-brake-line-corrosion-recall-204831p3.html *If you can tell me what the green/white wire you cut was near, I might be able to tell you what that wire was for. Was the wire solid green, with a white stripe? I looked quickly and didn't see any green wires with a white stripe associated with the brakes or abs system. Link to comment Share on other sites More sharing options...
Power2.5i Posted November 10, 2014 Author Share Posted November 10, 2014 Yes it was green with white stripe, it's behind the relay box, the top left if your looking from under the dash. And I added a lil wire to it to make it longer when I reconnected it. Link to comment Share on other sites More sharing options...
Power2.5i Posted November 10, 2014 Author Share Posted November 10, 2014 Did you repair and isolate the green/white wire under the dash? I didn't isolate it, reconnected it with a butt connector and a quick splice. Link to comment Share on other sites More sharing options...
apexi Posted November 10, 2014 Share Posted November 10, 2014 I'm thinking you cut the wiper deicer relay wire, which is harmless since our cars don't have wiper deicers. In the first image "GW" that I highlighted stands for a solid green wire with a white stripe. Link to comment Share on other sites More sharing options...
Power2.5i Posted November 10, 2014 Author Share Posted November 10, 2014 Yep, ok then that's not it. No wonder there is no relay in a lot of those spots lol. Then I don't know why it's on. That joint is gotta be the problem. But everything is as tight as can be. So I guess I will have to take it in :/ Link to comment Share on other sites More sharing options...
Power2.5i Posted November 10, 2014 Author Share Posted November 10, 2014 I'm thinking you cut the wiper deicer relay wire, which is harmless since our cars don't have wiper deicers. In the first image "GW" that I highlighted stands for a solid green wire with a white stripe. Thanks a lot for all the help man, really appreciate it! Link to comment Share on other sites More sharing options...
Power2.5i Posted November 12, 2014 Author Share Posted November 12, 2014 So found more fluid leaked by the rear passenger tire, the rest seem to be fine. Link to comment Share on other sites More sharing options...
SBT Posted November 12, 2014 Share Posted November 12, 2014 Probably part of the recall area at the rear. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Power2.5i Posted November 12, 2014 Author Share Posted November 12, 2014 I don't think it is that, cuz it was running down and it is on the plastic and I can wipe it all off. Link to comment Share on other sites More sharing options...
SBT Posted November 12, 2014 Share Posted November 12, 2014 The recall fixes the area just forward and above the rear trailing arm, where the brake line transitions from the first metal-to-rubber connection. Corrodes and leaks. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
apexi Posted November 12, 2014 Share Posted November 12, 2014 What color was the fluid by the rear tire? Milky white or like motor oil? I really think what you're seeing is the anti-corrosion wax, which is a milky white color. I took the pictures below after having the recall done on my car for a second time. They really went to town the second time around, you can see all the excess wax that dripped down onto my plastic trap door, and you can see the streaks on the underside of the plastic. *It also sounds like the technician who performed the recall on your car did a little extra and coated the joint connector next to your strut tower with the anti-corrosion wax. I don't think subaru called for the connector under the hood to get coated, but it certainly doesn't hurt. Link to comment Share on other sites More sharing options...
Power2.5i Posted November 12, 2014 Author Share Posted November 12, 2014 Could be but that's the only place on the car I see it and I can wipe it all off very easily. But I'll be taking it in here soon to have it diagnosed and fixed. Link to comment Share on other sites More sharing options...
Power2.5i Posted November 21, 2014 Author Share Posted November 21, 2014 So just took it in and it turned out to be the ABS Module kinda like we assumed it might be. Link to comment Share on other sites More sharing options...
