relative4 Posted November 3, 2014 Share Posted November 3, 2014 I have an '05 LGT 5MT wagon with Perrin 3" catted DP, OBX 3" catback, and Cobb stage 2 91 octane (I'm in Denver). What are my best next steps in getting more power without endangering the life of the engine? Will a bigger IC or catless UP make a difference, or do I need a bigger turbo to make any difference? Link to comment Share on other sites More sharing options...
Mike07LGT Posted November 3, 2014 Share Posted November 3, 2014 Regardless of power you should put a catless uppipe on your car anyway to avoid the risk of blowing your turbo/engine up 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
Max Capacity Posted November 3, 2014 Share Posted November 3, 2014 Big tmic like the new soon to be a group buy item, Grimmspeed tmic, then add some more boost. See my sig, that's on stock fueling. 93 octane. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MrTris Posted November 3, 2014 Share Posted November 3, 2014 Regardless of power you should put a catless uppipe on your car anyway to avoid the risk of blowing your turbo/engine up This. SO much this. Link to comment Share on other sites More sharing options...
MrTris Posted November 3, 2014 Share Posted November 3, 2014 Also, send a PM to JmP6889928, as, at some point, you will need a new turbo. I'm running his top-of-the-line units with an 11-blade billet wheel capable of pushing 20psi on a stage 2 setup. I'm making safe, reliable power on stock fueling. Great upgrade over stock, for sure. Link to comment Share on other sites More sharing options...
relative4 Posted November 3, 2014 Author Share Posted November 3, 2014 Regardless of power you should put a catless uppipe on your car anyway to avoid the risk of blowing your turbo/engine up How can the catted up-pipe blow up the turbo/engine? Link to comment Share on other sites More sharing options...
MrTris Posted November 3, 2014 Share Posted November 3, 2014 How can the catted up-pipe blow up the turbo/engine? The cat material in the UP can become dislodged and get pushed into the turbo, causing turbine failure. When the turbine fails, it causes shaft play, which causes the turbo to shed little metal flakes into the oil, which, circulate throughout the engine and eventually get caught in places they shouldn't, like in bearings. This seizes or "spins" a bearing, and causes the motor to fail. An engine rebuild is usually about 5k. A catless UP can be bought for as low as $75. Which would you prefer? Link to comment Share on other sites More sharing options...
Max Capacity Posted November 3, 2014 Share Posted November 3, 2014 Your new around here...the cat breaks lose and then the pices get eatten by the turbo. It's that simple. Once again, MrTris beats me to it... LOL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
relative4 Posted November 3, 2014 Author Share Posted November 3, 2014 The cat material in the UP can become dislodged and get pushed into the turbo, causing turbine failure. When the turbine fails, it causes shaft play, which causes the turbo to shed little metal flakes into the oil, which, circulate throughout the engine and eventually get caught in places they shouldn't, like in bearings. This seizes or "spins" a bearing, and causes the motor to fail. An engine rebuild is usually about 5k. A catless UP can be bought for as low as $75. Which would you prefer? Yikes! And thanks! I'm off to NASIOC for an UP. On a related note, what's the current wisdom on the turbo's banjo filter? Keep it or yank it? Link to comment Share on other sites More sharing options...
MrTris Posted November 3, 2014 Share Posted November 3, 2014 Yank it. Gone. Vamanos! Link to comment Share on other sites More sharing options...
MrTris Posted November 3, 2014 Share Posted November 3, 2014 Seriously, though, check your turbo while you're there. Also, are you tuned? If not, you should be. Link to comment Share on other sites More sharing options...
relative4 Posted November 3, 2014 Author Share Posted November 3, 2014 Getting confused on the STi UP - what years will work? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 3, 2014 Moderators Share Posted November 3, 2014 Any 02+ STi up pipe will work. WRX needs to be 06+ I believe. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
MrTris Posted November 3, 2014 Share Posted November 3, 2014 Getting confused on the STi UP - what years will work? 07+ It had to do with emissions, specifically cold-start emissions. So when they removed the cat in the UP, they added the airpump and, of course, also changed the heads to accommodate this. 05-06 had B25 heads and a catted UP. 07-09 had catless UP and D25 heads with the addition of an airpump, which is still in use today. Long answer, I know. Simple answer is anything 07 and up will fit fine. The good news is that all turbo Subarus can use the same UP. So if you can find a good aftermarket one for a decent price, go for it, too! Link to comment Share on other sites More sharing options...
relative4 Posted November 3, 2014 Author Share Posted November 3, 2014 So the STi UP 02-06 is catted? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 3, 2014 Moderators Share Posted November 3, 2014 So the STi UP 02-06 is catted? No, those are catless All STi up pipes are catless 06-14 WRX up pipes are catless 07-09 LGT/OBXT up pipes are catless "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
relative4 Posted November 3, 2014 Author Share Posted November 3, 2014 What about a 2015 STi? Will that work? I have a pretty good price on one of those. Link to comment Share on other sites More sharing options...
HOJeepster Posted November 3, 2014 Share Posted November 3, 2014 I have an '05 LGT 5MT wagon with Perrin 3" catted DP, OBX 3" catback, and Cobb stage 2 91 octane (I'm in Denver). What are my best next steps in getting more power without endangering the life of the engine? Will a bigger IC or catless UP make a difference, or do I need a bigger turbo to make any difference? I'm in Denver as well. How do you like the upgrade to a catted downpipe and exhaust? Is that obx too loud? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 3, 2014 Moderators Share Posted November 3, 2014 What about a 2015 STi? Will that work? I have a pretty good price on one of those. Will work just fine. Snatch it up! Anything under $60 or so is a pretty good deal. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
relative4 Posted November 3, 2014 Author Share Posted November 3, 2014 Seriously, though, check your turbo while you're there. Also, are you tuned? If not, you should be. How do I check the turbo? You mean just eyeball the blades when I'm swapping the UP? Regarding tuning, I have a Cobb AP and am running Stage 2. What else should I do? Link to comment Share on other sites More sharing options...
digger47 Posted November 3, 2014 Share Posted November 3, 2014 Contact Dave at cryotune performance and do a road tune or e tune. Link to comment Share on other sites More sharing options...
Connor Posted November 3, 2014 Share Posted November 3, 2014 How do I check the turbo? You mean just eyeball the blades when I'm swapping the UP? Regarding tuning, I have a Cobb AP and am running Stage 2. What else should I do? Check for shaft play on the exhaust outlet, you need to remove the downpipe to get the uppipe out. See how much play there is in the wheel (both side-to-side and in-and-out). Edit: as for what else you should do. I would add a DW65c (no tune needed) Pro tune Larger TMIC (or bulletproof mod) EBCS Equal length header if desired (You'll have the header off anyway for the uppipe) Also decide if you ever want to go external wastegate, if you do, nows the time. Link to comment Share on other sites More sharing options...
relative4 Posted November 4, 2014 Author Share Posted November 4, 2014 Thanks! Which of these gain me the most power without substantially risking engine damage? Also, do aftermarket up-pipes improve power compared to an STi catless? I'd be happy to throw down the extra $200 for 10 horsepower. Link to comment Share on other sites More sharing options...
Mike07LGT Posted November 4, 2014 Share Posted November 4, 2014 Thanks! Which of these gain me the most power without substantially risking engine damage? Also, do aftermarket up-pipes improve power compared to an STi catless? I'd be happy to throw down the extra $200 for 10 horsepower. Nope catless is catless... get the cheapest one you can find! 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
MrTris Posted November 4, 2014 Share Posted November 4, 2014 Also, do aftermarket up-pipes improve power compared to an STi catless? I'd be happy to throw down the extra $200 for 10 horsepower. Don't fall victim to one of the biggest fallacies of modding; You'll find that the difference in performance of a "big tube" UP vs a stock catless is only negligible at best, and the price points are all across the board. A $75 UP is pretty much as good as a $200 UP, just doesn't come with brand snobbery. Link to comment Share on other sites More sharing options...
