Scooby Fan Posted October 28, 2014 Share Posted October 28, 2014 (edited) Hi all.......there was a thread like this in the 4th Gen section back when I had a 2006 LGT sedan......post your car...your age/gender...your type of work...how many Subaru's owned....mods to current car (Link if there are lots of mods.) and anything else that might interest the rest of the forum. 2013 Legacy 3.6R Limited - Twilight Blue Metallic Male - 69 years young Club fitter in the golf business Have owned 6 Subies total Mods...minor...Wheels, tires, STi RSB, OEM spoiler, side moldings, fogs (Wired independently).de-badged, Magnaflow exhaust tips, milk jug delete/funnel intake. (Funny how, as you get older, the mods become less exotic) Cheers Edited October 29, 2014 by Scooby Fan Link to comment Share on other sites More sharing options...
bill.in.mtl Posted October 28, 2014 Share Posted October 28, 2014 I'll play 2010 Legacy 3.6R Silver Male - 50 years old Plant Manager - Manufacturing I've had four of five Subies total - starting with an '85 XT Mods.....really none, probably first car in over 20 years - do have Rally Armor mud flaps if that helps..... sent from my GT-P3113 using Tapatalk HD Link to comment Share on other sites More sharing options...
testa422 Posted October 29, 2014 Share Posted October 29, 2014 (edited) 2013 legacy sport 2.5 - ice silver male - 30 years old chef/dietary coordinator this is my first subaru and im in love! mods...konig wheels, tein springs, all led lighting, custom exhaust, corazon fstb, liberty rear badge...thats all the major-ish mods Edited October 29, 2014 by testa422 Link to comment Share on other sites More sharing options...
RIRED11 Posted October 29, 2014 Share Posted October 29, 2014 I'm in!! 2011 Legacy 2.5 Limited - Ruby Red Pearl Female - 49 (ouch) Owner/operator of homecare & errand business also work @ local coffee shop This is my 3rd Subaru No mods currently - but someday I would love to upgrade the exhaust and get rid of that silly cutout in the rear bumper Link to comment Share on other sites More sharing options...
s2baru Posted October 29, 2014 Share Posted October 29, 2014 2010 LEGACY GT LIMITED---GGM Man-26 Sales advocate for Verizon, Tmobile, and AT&T Mods hehehehe...BUT wait...THERE's MORE!!! Power/Engine/Exhaust COBB ACCESSPORT RACERX TMIC...thermal coated RACERX charge pipe....matched with turbo xs 50-50 bpv INVIDIA CATLESS DOWNPIPE..custom 3inch. mid split to 2.25 PERRIN WRX 08+ AXLE BACK MUFFLERS BLOCK Outfront closed deck 2.5L block, Sublet Machine shop, block, resurface flywheel, fit rods, balance, polish crank, Sublet Nitrous Coating for pistons/skirts 4 King bearing Sets Mains + Rods 26180 Manley, Valve Spring and retainer Kit, EJ 1022 GSC, Viton 6mm Valve Stem Seal Set EJWT Killer-B, Subaru Windage Tray 10105ab280 Subaru, Engine Gasket Set, 10-12 LGT 15021-hdtz Clutchmasters, FX300, push type C4264-040 Cometic Head Gasket, Subaru EJ25, 100mm bore, .040" 2 260-4701 ARP, Head Studs, Subaru EJ20/EJ25 Parts JE Piston Set, STD 99.5mm Parts Manely turbo Tuff Con Rods GSC Stage 1 Cams, 08+ STi SB0001 Cosworth, Subaru EJ Timing Guide 11139-8 Manley, Extreme Duty 33mm exhaust Valves (+1mm) 11140-8 Manley, Race Master Intake Valves, 37mm (+1mm) Sublet Machine Shop, heads, fit new cams, radial valve cut, reset lash, install viton seals, oversize valves, blend bowls, performance springs. 70lbs seat 180lbs @ .420" Oil pump, JDM STi 12mm SubaruOil Cooler, 10+ LGT Gates Performance timing belt kit Suspension/wheels TEIN STREET BASIS Coilovers KARTBOY FRONT/REAR ENDLINKS WHITELINE FRONT 24MM SWAY BAR WHITELINE REAR 22MM SWAY BAR KARTBOY POSITIVE SHIFT KIT... KDT901 KARTBOY REAR DIFF FRONT MOUNT BUSHING ..KDT905 KARTBOY REAR DIFF IN MOUNT CRADLE BUSHING ...KDT903 KARTBOY REAR SHOCK ASORBER BUSHING...W0505 KARTBOY LOWER INNER FRONT CONTROL ARM BUSHING...W0506 KARTBOY ANTILIFT/CASTER CONTROL ARM INNER REAR BUSHING...KCA334 GROUP-N 5MT TRANS MOUNT MEGAN RACING 08+ WRX REAR LOWER CONTROL ARMS MEGAN RACING 08+ WRX TOE KIT Wheel setup: One off custom Forgestar F14 in sunset orange 19x9 +35 ordered from Moore peformance Nitto Motivos 255/35r19 ...minor pull on front done by Xissix (nate) COSMETIC; flat blacked out front headlights, 20tint, stock wheels painted black, led interior lights and turn signals, BaysonR JDM replica lip (colormatched) Invasion Fabworks alternator shroud Smoked vinyl rear taillights Rally ARMOR FLAPS. Link to comment Share on other sites More sharing options...
bigbiz187 Posted October 29, 2014 Share Posted October 29, 2014 2011 Legacy 2.5 Limited, Caramel Bronze Male - 35 PC support technician 1st Subaru, clearly waited too long to buy one Mods - So far just a few cans of Plasti Dip and some fuzzy dice. Plenty on my "to do" list, I'll probably start with a cat back exhaust system. Link to comment Share on other sites More sharing options...
coppertone Posted October 29, 2014 Share Posted October 29, 2014 2010 2.5GT Limited Obsidian Black Male: 49 Retired RCE springs Bilstein shocks Hid headlights All led exterior lights 2014 Oem Sport wheels Nameless Performance custom mufflers F/r sway bars Tint all around Subaru heavy duty floor/trunk mats STi short shifter Custom (DRKNESS) shift knob Custom two tone with off colored stitching shift boot Custom fiberglass molded gauges Alpine INA-910 dd head unit Alpine C800 RUX controller Alpine H800 DSP Alpine microbypass Focal Beryllium tweeters Dynaudio Esotar2 650 midbass Stereo Integrity BM MKIV 12" shallow mount subwoofer Brax X2400.2 amp Brax X2000.2 amp Custom rca wrapped in tech flex Sound deadening throughout front & rear Sears Platinum diehard battery Free flow air filter Roof spoiler Front lower spoiler 2010 2.5GT limited is for sale. Link to comment Share on other sites More sharing options...
DJMajickMan Posted October 29, 2014 Share Posted October 29, 2014 (edited) 2011 3.6R Limited Silver Male: 40 IT consultant 1st Subaru Custom Takeda intake with intake box removed, Silicone Reducer 90° bend 4" to 3", 3" Stainless steel joiner, Performance 6" Straight Aluminum intake tube 4" diameter, and a K&N RC-5171 High Performance Universal Clamp-on Air Filter tucked away behind the front bumper. Cosmetic: BaysonR JDM Front lower spoiler Extreme II rear window spoiler Tuned by AMR Edited October 29, 2014 by DJMajickMan Link to comment Share on other sites More sharing options...
Zee199969 Posted October 29, 2014 Share Posted October 29, 2014 2010 LGT-L SWP 100k miles Male: 38 Medical Research 1st subie Mods: Morimoto Elite HIDs 5000k [ame=http://www.amazon.com/gp/product/B006KBLEJO?psc=1&redirect=true&ref_=oh_aui_search_detailpage]AEM Dryflow air filter[/ame] Fumoto Drain Valve 2012 Legacy folding mirror housings 2015 WRX Perrin Brass Shifter Bushing 2015 WRX 20mm RSB 2015 WRX Perrin WRX Shift Stop Sylvania LEDriving LED Bars LED replacements for parking. reverse, turn signals, and interior lights Tapturn module RCE Blacks with 08-14 WRX Koni Inserts Perrin Exhaust tips Clutch Damper Valve Delete Cobb AP V2 stage 1 93oct Cobb Tuned Milk jug delete Raceseng Slammology Shift Knob 2015 WRX Perrin Short Shifter Adapter CMOD Grille Hella Sharptones XXR 550 18x8.75 +36 Conti DWS06 255/40/18 Southbend stage 2 clutch FJK1001-HD-O Tranquil TSK-3 Primitive Skidplate 1/8" GoFastBits Mach 2 BPV: T9133 2013-14 headlight housings TYC branded DAMD D Steering Wheel Primitive Midplate Grimmspeed 2015+ WRX TMIC WindFireAuto Courtesy Lights with custom L7 logo GTSpec Front Strut Tower Brace: GTS-SUS-1387 Grimmspeed Plate Relocation Kit: 094029 Grimmspeed Plate Delete Prova Rain Guards Ken Brennan LED Backlit Badge Ultra Racing RSTB: UR-RE2-1488 AVO Front LCA bushings SPC 67660 Rear Control Arms Hardrace 7720 Front Engine Mount Perrin Steering Dampener Lockdown Cusco MCB S687-561-B Koyorad Radiator: VH091662 STi Thermostat: 21210AA030 Samco Radiator Hoses: TCS516/C GTSpec Rear Strut Tower Brace: GTS-SUS-1425Hardrace Engine Mounts Group-N Transmission Mount My "Build" Link to comment Share on other sites More sharing options...
acumenhokie Posted October 29, 2014 Share Posted October 29, 2014 Car: 2010 LGT Age: 33 (and feeling old) Job: IT Manager Heritage: 1st Subaru (have since bought a 2nd and helped 2 friends buy their first) Mods: All of them on the market plus a few custom made ones. Link to comment Share on other sites More sharing options...
JJBerk Posted October 29, 2014 Share Posted October 29, 2014 2012 LGT Female, 45 IT Trainer/Support 5 Subaru's (2004FXT (sold), 2006LGT (sold), 2010 Impreza, 2011 Forester (sold), 2012 LGT Mods: - not much! 22mm RSB, tint, 4"exhaust tips, STI short throw shifter (PO installed) Link to comment Share on other sites More sharing options...
km580 Posted October 29, 2014 Share Posted October 29, 2014 2011 LGT Graphite Grey Met Male 47 Job, The PO-Leese 6 Subie's Mods, Eibach Pro kit, McDowell Tuned, Nameless ABE, Perrin Shifter bushing, Group N Trans mount, Cross member bushings, HID's Blacked out headlight housings 22mm Whiteline RSB Fat people are hard to kidnap!!! Link to comment Share on other sites More sharing options...
DeltaSniper Posted October 29, 2014 Share Posted October 29, 2014 2012 Legacy GT Male 24 Job : Office Manager in the Non Profit Sector Heritage : 4th Subaru (2001 Forester (Sold), 2002 Outback Wagon (Sold), 2010 Legacy (Sold), 2012 LGT) Mods : A lot. Link to comment Share on other sites More sharing options...
red50fordf1 Posted October 29, 2014 Share Posted October 29, 2014 (edited) 2010 LGT SWP Male 25 Former: Mechanic Current: Product Manager - Software Development (they pay more ) 2nd subaru Mods: Perrin brass shift bushing & shift stop RX TMIC coated RX charge pipe Synapse BPV Invidia CBE AEM air filter L7 badges AP OTS stg 1 tune Edited October 29, 2014 by red50fordf1 Link to comment Share on other sites More sharing options...
Perscitus Posted October 29, 2014 Share Posted October 29, 2014 - 2010 3.6R Premium - Graphite Gray Metallic - Male - 33 (feeling like acumenhokie) - by day: Market/Credit Risk Business Analyst (aka pricing monkey) by night: grease monkey by school: mechanical/mechatronics engineer - 1st Subaru (sealed the deal on brother's 2015 WRX and helped family pickup an XV) - a few mods here and there Link to comment Share on other sites More sharing options...
duhst Posted October 29, 2014 Share Posted October 29, 2014 -2010 2.5i Premium - Satin White Pearl -Male, 28 -Supplier Onboarding Manager, Overstock.com -1st Subaru!! -Mods, Tein S-Tech Springs and 18in Stern wheels. Link to comment Share on other sites More sharing options...
LegacyZero Posted October 29, 2014 Share Posted October 29, 2014 -2011 SWP LGT -Male, 29 -Mechanic -Only one Subaru, so far... -Tint, plastidip, swift springs, muffler deletes, very near future tune. Link to comment Share on other sites More sharing options...
Jhmason21 Posted October 29, 2014 Share Posted October 29, 2014 2011 2.5i Premium Male 29 Estimating Department Manager for construction company 4th Subaru: 2002 Bugeye WRX Wagon (sold:(), 2012 WRX Sedan (sold), 2012 Impreza 2.0 Premium (wife) Mods: Tint. Planned mods: RetroFit kit, OEM Fogs, LGT 18"s, maybe a RSB. Honestly love a stock suspension DD again.. so soft and comfy Link to comment Share on other sites More sharing options...
islandborn Posted October 29, 2014 Share Posted October 29, 2014 2012 Black LGT Male - 40 (but I refuse to act that old) High School teacher and Club swim coach 1st Subaru Mods:....uh....on my third turbo with a built block... so a bunch - check my build thread if you're that interested. Link to comment Share on other sites More sharing options...
RailKill Posted October 29, 2014 Share Posted October 29, 2014 2014 SWP Sport Male - 35 Signal Maintainer for the largest and busiest commuter railroad in the US 4th Subaru: 2006 2.5i, (2) 2011 2.5i's, and now my '14 Sport Mods (all minor): 18" Enkei TSP6 wheels, Eibach Pro Kit, LED's throughout, debadged, rear window spoiler, 35% tint all around, 22mm Whiteline RSB, ISC rear adjustable LCA's and an OEM GT dual exhaust (once I pick it up from wrxwhit) Link to comment Share on other sites More sharing options...
redstriker Posted October 29, 2014 Share Posted October 29, 2014 2010 Blue Premium LGT Age: 22 Computer store sales/computer builder/pizza delivery driver/IT networking 1st Subaru Mods - a lot and trying to get the best setup for Autocross. Check my build thread. Link to comment Share on other sites More sharing options...
BadTrainDriver Posted October 29, 2014 Share Posted October 29, 2014 2013 Subaru Legacy 3.6R Limited/Loaded. Female, 23yrs. old. Professional escort, dancer, adult performer. First Subaru. I like it OK. 100% Stock. Link to comment Share on other sites More sharing options...
dgoodhue Posted October 30, 2014 Share Posted October 30, 2014 2012 2.5i Premium 6MT Make, 41 years old Electrical Engineer 1st Subaru Mods - STI STS, 19mm swaybar, tune, 2011-4 WRX wheels/tires and Nokian snow tires on the stock rims Link to comment Share on other sites More sharing options...
cww516 Posted October 30, 2014 Share Posted October 30, 2014 (edited) 2011 LGT w/ nav, black Male, 29 Service engineer for a major heavy truck manufacturer, the segment I'm in manufactures airport snow removal and fire rescue vehicles. I'm a mechanical engineer by degree, but I get plenty of opportunities to pretend to be an electrical engineer as well. 1st Subaru (of 2, now) Mods: OTS stage 1, STI STS, Perrin shifter bushing and shift stop, damper delete, Podi boost gauge to replace my deceased factory SPT boost gauge, 20mm WRX rear sway bar, 18"x8.5" +45 Enkei Raijins with 245/45R18 S04 Pole Position tires, Koni shocks and Eibach springs, SPC rear LCAs, GrimmSpeed TMIC, and plenty of other stuff waiting for warmer weather. Added an '06 Baja to the fleet about a year ago, since buying a second car seemed like a more responsible choice than modifying my only mode of transportation. Couldn't leave that one well enough alone either, so I swapped in the front seats from a bugeye WRX to keep my head from rubbing on the roof. Edited February 22, 2018 by cww516 Link to comment Share on other sites More sharing options...
stevenc1703 Posted October 30, 2014 Share Posted October 30, 2014 2011 RRP 3.6r Male 28 Lab technician for Green Bay Pkg 1997 legacy L (wrecked) and 2011 legacy Exhaust, intake, tune, konis, H&Rs, STBs, bigger sway bars, lca's, & some body work Link to comment Share on other sites More sharing options...
