Chris Westfall Posted October 26, 2014 Share Posted October 26, 2014 Alright guys I really need your help. I own a 2001 subaru outback and after 20-30 mins of driving, once its warmed up. It gets hard to shift and makes a loud clunking noise in the front end. Even in neutral slowing down it makes noise. Anyone have any idea what that could be. I dont think Im losing my transmission, I think it has something to do with the clutch. Thanks in advance. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 28, 2014 Share Posted October 28, 2014 After that long of a time...I have no idea. Any noise when you make a tight turn...may be a CV joint is going bad. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Chris Westfall Posted October 28, 2014 Author Share Posted October 28, 2014 No noise while turning, no.. I changed the transmission oil yesterday and it was perfect for 24 hours, then started getting hard to shift and made the noise again...Im very upset. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 30, 2014 Share Posted October 30, 2014 How is the clutch fluid ? may be its time to replace it. I think that would be the next step. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Chris Westfall Posted November 3, 2014 Author Share Posted November 3, 2014 Clutch oil seems very dark. I've never flushed or changed the clutch oil. You think that would make the front end have some sort of clunk to it after warming up? And make it hard to shift? Link to comment Share on other sites More sharing options...
Max Capacity Posted November 4, 2014 Share Posted November 4, 2014 The clutch fluid should be yellowish to clear. Mine was just replaced. I'm much happier with clutch feel. The clunk in the front end is a different issue. It could be a number things. loose heat shield or end links on the sway bar. THese car are know for both. I just cut the middle heat shield of the crossover pipe and DEI heat wraped it. I also just replaced the front sway bar bushings because I had a rattle over rough pavement. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Chris Westfall Posted November 4, 2014 Author Share Posted November 4, 2014 Okay but it only starts clunking when it gets hard to shift... Link to comment Share on other sites More sharing options...
Max Capacity Posted November 4, 2014 Share Posted November 4, 2014 How are the CV joints ? I'm just guessing here now... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
