jakeafton Posted October 26, 2014 Share Posted October 26, 2014 Pretty much what the title says...I picked up a white 98 LGT with a blown engine for cheap. Been looking for an engine. I found one out of a 95 Legacy L for cheap. Full engine, just pulled for part out. How hard is the swap? Will ecu for the lgt work? The guy said the 2.2 was non-egr... Link to comment Share on other sites More sharing options...
johnegg Posted October 27, 2014 Share Posted October 27, 2014 as far as swaps go it is one of the easiest. but the no-EGR will give you a CEL trouble code, forever. it will run fine, but you will have the light/ code. if you or your state inspection can live with that, no problem. another solution is to get a complete intake manifold from an EGR 2.2L car, 95 - 98 and use that. you will have to do the ''non-egr work around'' but that is easy. just a few pieces of hose and connectors. Link to comment Share on other sites More sharing options...
jakeafton Posted October 27, 2014 Author Share Posted October 27, 2014 That's awesome news. It sucks about the CEL. I'm assuming the 2.2L is fairly, ehrm...slow. I wonder what the gas mileage would be like for a healthy one. State inspection is not an issue. However, selling the car I'd like to get rid of the code. "Non-egr work around"? I'll search for that...Just have to find a complete intake manifold from an EGR 2.2L...somewhere... Link to comment Share on other sites More sharing options...
johnegg Posted October 27, 2014 Share Posted October 27, 2014 I'm assuming the 2.2L is fairly, ehrm...slow. if you have not driven the ej25 car, you will not notice a difference. the ower curve is a little different, less low end for the ej22, but it will run the car just fine. I wonder what the gas mileage would be like for a healthy one.same, both engines are rated about the same. i get 23 mpg on the hiway in my 97GT w/ ej22. (70mph) that is not great in my opinion, but it is what i get. and i don't feel like chasing 2mpg with lots of time and labor. i should, but i'm not. a complete intake can be had for about $65 - $75 @ http://www.car-part.com be sure to read up on some of the ''things to do '' before you install your ej22, like the oil separator plate, A MUST. front oil seals, recommended but probably done with the timing parts. all new timing components, not a must since a failure will not damage anything. maybe the valve cover gaskets if they show oil wet underneath. Using a NON-EGR engine in Subaru with EGR - Submit a Tip or Mod to the USRM - Ultimate Subaru Message Board Link to comment Share on other sites More sharing options...
jakeafton Posted October 28, 2014 Author Share Posted October 28, 2014 The engine is non-interference? I'm gonna search around for this oil-separator plate... I found an IM from a 96 EJ22 automatic, is that EGR? Without seeing pictures, details are pretty fuzzy about what years / engines are EGR and which aren't. That post also mentions "You'll need to get a single-port exhaust header/y-pipe for the '96-'98 EJ22" baehh....is that not stock? Link to comment Share on other sites More sharing options...
johnegg Posted October 28, 2014 Share Posted October 28, 2014 I found an IM from a 96 EJ22 automatic, is that EGR? yes, 99% sure. a visual will confirm. EGR is found on MOST ej22s from auto trans cars. it is not found on most ej22s from manual trans cars. i would say all, but i know one guy, a very knowledgeable and experienced guy, who swears he has seen an egr engine in a manual trans car. i cant prove he is wrong, but i can not find ANY documentation to support his experience. so we say EGR is on MOST auto trans ej22 cars, 95 - 98. the 98 GT ej25 engine has dual port exhaust and EGR, (auto and manual) . the 95 ej25 engine has dual port exhaust and no egr on manual trans cars. you already have the correct y-pipe. if this were ''giving blood to the red cross'', the 95 ej22 (from and auto trans car) would be the universal donor, 0-Neg. it will fit any car 95 - 98, easily. Link to comment Share on other sites More sharing options...
