Hugo L. Posted October 22, 2014 Share Posted October 22, 2014 Hi, I recently noticed that if I try to accelerate from around 3k rpm in, say, 3rd gear, that car would shudder before I would feel any acceleration. Yesterday I was on the highway, crusing at around 2.5k rpm, and instead of downshifting, I just gave it some gas (not hard, just gradual increaed throttle input). Well, the rpm needle just jumped to 5k rpm and the car barely budged, until I let off the gas a little, and it seems like it «picked up», and then I accelerated. Seems like it's doing that more and more, in pretty much every gear. Ironically, accelerating hard in 1st gear doesn't seem to be the problem.< Time to change the clutch? Link to comment Share on other sites More sharing options...
Max Capacity Posted October 22, 2014 Share Posted October 22, 2014 Yep. Do you know to get a smfw and a good clutch ? Must use a 06-11WRX smfw which is the same as a 07-09 Legacy GT smfw. I have good luck with Spec clutches seem Southbend gets good marks too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
