legacyshawn Posted October 18, 2014 Share Posted October 18, 2014 I'm using the 2.1amp USB charger port to power a media player for my nav screen and I seem to be getting noise on the display and through the speakers when it's plugged in. I had a wall adapter putting out the same amps at 5 volts though a car inverter without any noise..now with the car charger I get noise like a ground loop with alternator noise but I get the same noise in the speakers and the screen even with the car off. Is there a small product I can use in line between the charger and the media player that could regulate the voltage or suppress sound from the USB power port? This is the charger [ame=http://www.amazon.com/gp/aw/d/B00H2ZU72W]TopG [Lifetime Warranty] Dual USB Ports 3.1A Portable USB Car Charger for iPhone 5 5S 5C 4 4S,iPad 4 3 2,iPad mini,iPad air Battery Power Supply for All Apple Device (Lightning Cable/Adapter Not Included)- (Black+Silver):Amazon:Cell Phones & Accessories[/ame] And the media player http://www.miccatron.com/micca-speck/ Link to comment Share on other sites More sharing options...
theflystyle Posted October 25, 2014 Share Posted October 25, 2014 Sounds like a possible grounding issue. Link to comment Share on other sites More sharing options...
legacyshawn Posted October 26, 2014 Author Share Posted October 26, 2014 Yeah but noise with the engine off? Link to comment Share on other sites More sharing options...
compsurge Posted October 26, 2014 Share Posted October 26, 2014 Absolutely. It likely does not have a built-in ground loop isolator. The DC/DC converter is generating the noise and is backfeeding your audio electrical system. Link to comment Share on other sites More sharing options...
RedFloyd Posted October 27, 2014 Share Posted October 27, 2014 Some chead 12V - 5V converter generate some high frequency noise that can be heard in the audio signal. This noise is caused by the switch mode converter inside the converter. A good desing won't generate any noise. You can try to add a filter on the 5V supply (inductor - capacitor). It may help a little. Also, try to have the shortest connection as possible. Link to comment Share on other sites More sharing options...
