rcruz17 Posted October 18, 2014 Share Posted October 18, 2014 So in short went to install catless uppipe last week found my vf40 destroyed I got the car 4 months ago. So got online found a guy selling VF52 said he took it out at 20k to upgrade even sent it to me in the blouch box...turbo looks new no shaft play pretty simple installed it and car started overheating. Its smoking or burning coolant from under or around turbo constant stream of smoke from that area. I even bleed the coolant system car never overheated before prior to this. I double checked all my connections and even replaced some clamps with worm clamps. Link to comment Share on other sites More sharing options...
MrTris Posted October 18, 2014 Share Posted October 18, 2014 I'd recheck all the water line connections both ON the turbo, and back to the engine. There may also be a coolant leak inside the turbo, as well. Are you tuned for the VF52? I see no mention of a new tune. . How 'destroyed' was your VF40? Sounds like a new shortblock might be in your future; see my Shopping List and build thread. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 18, 2014 Share Posted October 18, 2014 You need to make sure there turbo coolant tank is full of coolant, check that and report back. MrTris will have to help you more, I'm headed away in a few minutes. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rcruz17 Posted October 18, 2014 Author Share Posted October 18, 2014 So after some digging around the lower turbo coolant hose had some slits in it on the bottom connector which i didnt even touch. I replaced it with a 1ft piece that curves around nicely no kinks at all and used some worm clamps and tighten them really good. So i bleed coolant again both reservoir drove car around using torque app temp didnt past 203f and went as low as 190f i barely drove past 20mph.. . But after like 40 minutes i got some smoke from under behind turbo area...yet temperature was at 197f steady. Before i turned car on i check the banjo bolts for any leaks or moisture around turbo and saw none and checked the lower turbo coolant reservoir hose on both ends because i tugged on it a little to get it back in reservoir. Link to comment Share on other sites More sharing options...
08Legacy-GT Posted October 20, 2014 Share Posted October 20, 2014 So after some digging around the lower turbo coolant hose had some slits in it on the bottom connector which i didnt even touch. I replaced it with a 1ft piece that curves around nicely no kinks at all and used some worm clamps and tighten them really good. So i bleed coolant again both reservoir drove car around using torque app temp didnt past 203f and went as low as 190f i barely drove past 20mph.. . But after like 40 minutes i got some smoke from under behind turbo area...yet temperature was at 197f steady. Before i turned car on i check the banjo bolts for any leaks or moisture around turbo and saw none and checked the lower turbo coolant reservoir hose on both ends because i tugged on it a little to get it back in reservoir. check the banjo bolt? REMOVE the banjo bolt =) save your turbo They should make october not breast cancer awareness mount, but banjo bolt awareness month (save the turbos!) 2017 Subaru STI 2008 Subaru Legacy 2.5i limited Link to comment Share on other sites More sharing options...
rcruz17 Posted October 20, 2014 Author Share Posted October 20, 2014 Remove which the coolant banjo bolts? What are the torque specs for them? Link to comment Share on other sites More sharing options...
MrTris Posted October 20, 2014 Share Posted October 20, 2014 Remove which the coolant banjo bolts? What are the torque specs for them? We don't remove the banjo bolts themselves, what we're referring to is the filter inside them. Rear of passenger side head, and the driver's side front, which is behind the timing cover. Link to comment Share on other sites More sharing options...
rcruz17 Posted October 20, 2014 Author Share Posted October 20, 2014 Oh the oil banjo i did that as part of my uppipe install this thread is regarding my smoking/overhesting problem Link to comment Share on other sites More sharing options...
Max Capacity Posted October 20, 2014 Share Posted October 20, 2014 Remove which the coolant banjo bolts? What are the torque specs for them? Tight enough. Just make sure its tight, if it leaks you can alway tighten it a little more. Did you use new crush washers ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MrTris Posted October 20, 2014 Share Posted October 20, 2014 Tight enough. Just make sure its tight, if it leaks you can alway tighten it a little more. Did you use new crush washers ? This may actually be the crux of the issue at hand - Link to comment Share on other sites More sharing options...
rcruz17 Posted October 20, 2014 Author Share Posted October 20, 2014 No i did not replace the copper gaskets. but also it is white smoke does that not mean coolant being burnt? I did not think this was regarding an oil problem. PS i have driven the car for about 20 minutes a couple times and no overheating or smoking. temperature stays around 190f Link to comment Share on other sites More sharing options...
MrTris Posted October 20, 2014 Share Posted October 20, 2014 PS i have driven the car for about 20 minutes a couple times and no overheating or smoking. temperature stays around 190f The banjo bolts aren't just for oil, they're used on the coolant lines, too. If you've got no more smoke, you might be out of the woods, so to speak. Link to comment Share on other sites More sharing options...
rcruz17 Posted October 20, 2014 Author Share Posted October 20, 2014 I may be in the clear but last time it smoked it was after about 40minutes of engine running. Link to comment Share on other sites More sharing options...
rcruz17 Posted October 20, 2014 Author Share Posted October 20, 2014 I did not touch the coolant lines on the turbo. the ones I got had lines attached already so I left it as is. Link to comment Share on other sites More sharing options...
rcruz17 Posted October 20, 2014 Author Share Posted October 20, 2014 sexy photoshoot of what I was replacing. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 20, 2014 Share Posted October 20, 2014 Are you tuned for that VF52? Very important... Smoke from coolant has a sweet smell to it. Smoke from oil, well that stinks pretty bad.. Should be easy to tell the diff. Link to comment Share on other sites More sharing options...
rcruz17 Posted October 20, 2014 Author Share Posted October 20, 2014 Are you tuned for that VF52? Very important... Smoke from coolant has a sweet smell to it. Smoke from oil, well that stinks pretty bad.. Should be easy to tell the diff. doesnt burning oil have some color to it? or gray haziness at least? this is pure white smoke... and it makes me like choke up and cough when i smell it. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 21, 2014 Share Posted October 21, 2014 IMO you need to get under the car with a good flash light. Look at the back of the passenger side valve cover and CV boot. If nothing there, look higher up... Get the idea ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 21, 2014 Share Posted October 21, 2014 IMO you need to get under the car with a good flash light. Look at the back of the passenger side valve cover and CV boot. If nothing there, look higher up... Get the idea ? Could be that or your oil return line from the turbo. The OEM clamp is flimsy.. Link to comment Share on other sites More sharing options...
rcruz17 Posted October 21, 2014 Author Share Posted October 21, 2014 Could be that or your oil return line from the turbo. The OEM clamp is flimsy.. I triple checked the oil return line when installing it wasnt to hard to do actually. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 21, 2014 Share Posted October 21, 2014 So did you go for a drive, and then open the hood and carefully checked the origin of the leak? Link to comment Share on other sites More sharing options...
GTTuner Posted October 21, 2014 Share Posted October 21, 2014 sexy photoshoot of what I was replacing. Something went thru that turbo....some type of debris did that damage. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 21, 2014 Share Posted October 21, 2014 Now tell me you used a new oil return hose not the 10 y/o one ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rcruz17 Posted October 21, 2014 Author Share Posted October 21, 2014 Now tell me you used a new oil return hose not the 10 y/o one ? Return line looked fully intact I used a worm clamp on turbo side made installation easier. Link to comment Share on other sites More sharing options...
robinlsb Posted October 21, 2014 Share Posted October 21, 2014 Return line looked fully intact I used a worm clamp on turbo side made installation easier. :eek::eek: "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
