Chayser Posted October 15, 2014 Share Posted October 15, 2014 Hey everyone, I am having trouble with my 1997 legacy, but cant figure out what the issue is. Whenever I shift from 1-2 and 2-3, I hear a grinding noise in between shifts. The same noise seems to happen with gears 1-3 if I rev up to around 3k or more, then while engine braking I can hear a grinding noise at higher RPM's. I read around and heard this might just be a normal sound with the subaru drive-train, but I find that kind of hard to believe. Personally, it annoys the shit out of me, so I am trying to decide on the right course of action. First time Subaru owner so looking for any advice on the matter. Link to comment Share on other sites More sharing options...
Zues Marine Posted October 15, 2014 Share Posted October 15, 2014 I read around and heard this might just be a normal sound with the subaru drive-train, but I find that kind of hard to believe. . yeah i wouldnt say this is all too common with a proplerly running trans.. clutch fork bent or cracked maybe? Link to comment Share on other sites More sharing options...
snederhiser Posted October 16, 2014 Share Posted October 16, 2014 Hello; I would drain the transmission and see if the fluid is contaminated with metal shavings. You might be experiencing a bad clutch, throwout bearing, pilot shaft bearing, or not adjusted correctly. Steven. Link to comment Share on other sites More sharing options...
Chayser Posted October 21, 2014 Author Share Posted October 21, 2014 Yeah, I was planning to change the fluid when I get near my tools again. The clutch is definitely toward the end of its life, but if I decided to change the clutch, thought Id check around about anything else that might be causing this weird grinding. Thanks for the advice guys. Ill keep you posted if I find something when I drain it soon. Link to comment Share on other sites More sharing options...
