Bezz Posted October 9, 2014 Share Posted October 9, 2014 I have an '08 SpecB to my knowledge I have a Torsen Rear Differential from factory. Is this any different than the Rear Diff. in STi's? I know there is an updated locking kit for STI's to make them more aggressive that works on SpecB's so I would assume so. The question came up when I found an STI diff. (from an '08) for sale for very cheap but couldn't remember if it's the exact same diff and not worthwhile for any reason. Any wise words appreciated. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 9, 2014 Share Posted October 9, 2014 Check out the sticky's at the top of the related forums. the answer may be there. I'm thinking they are the same. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
robinlsb Posted October 9, 2014 Share Posted October 9, 2014 A front LSD is where you need to spend the money, not on the rear LSD. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
Bezz Posted October 9, 2014 Author Share Posted October 9, 2014 Yeah I read the sticky and all it says is "The 07+ spec b comes with a torsen/helical in the rear already. But if owners want, they can swap in the STI clutch type read Diff." It doesn't say which STI Diffs have clutch type diff. (all?) or how much of an actual upgrade it is. From personal experience clutch types do feel way better but the upgrade FAQ is just very vague. If I can get an upgrade for very cheap I'm all for it, but if it's a mild upgrade and I'm better off saving my money for something better I will. Also I guess it would be nice to know if anyone has previously done the swap and have some of their thoughts on the matter. And yes I agree. open front Diff. sucks majorly, this just happened to land on my doorstep. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 9, 2014 Share Posted October 9, 2014 If you go to the sticky for "oppossedforces" at the top of the very first forum here. you can selcect the STI and SpecB and see the rear diff's parts. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Bezz Posted October 9, 2014 Author Share Posted October 9, 2014 Sweet, Thanks. Link to comment Share on other sites More sharing options...
Sgt.Gator Posted October 12, 2014 Share Posted October 12, 2014 Yeah I read the sticky and all it says is "The 07+ spec b comes with a torsen/helical in the rear already. But if owners want, they can swap in the STI clutch type read Diff." It doesn't say which STI Diffs have clutch type diff. (all?) or how much of an actual upgrade it is. From personal experience clutch types do feel way better but the upgrade FAQ is just very vague. If I can get an upgrade for very cheap I'm all for it, but if it's a mild upgrade and I'm better off saving my money for something better I will. Also I guess it would be nice to know if anyone has previously done the swap and have some of their thoughts on the matter. And yes I agree. open front Diff. sucks majorly, this just happened to land on my doorstep. Both the 08 Spec B and 08 STI use a Torsen rear diff. 04-06 STI used plated(clutch). It's not worth the swap unless you are doing serious rally racing where you might get a rear wheel off the ground. As mentioned earlier, the biggest bang is putting in a front LSD. Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
