Crazy_Pilot Posted October 9, 2014 Share Posted October 9, 2014 Anyone else encountered this? I have a tiny bit of rust showing on the two panel joints that are under the front door sills. I've sanded and POR-15'd the right side. I'll colour over it with some touch-up paint to blend everything in. I'm also going to leave the sills off so the rust-proofing guys can load up the rocker panel with oil. I have a theory that the edges of the sill plate, which are quite sharp, have worn through the paint on those panel edges and allowed the rust to start. Driver's door: Passenger door with POR-15: Link to comment Share on other sites More sharing options...
Max Capacity Posted October 9, 2014 Share Posted October 9, 2014 Check the bottom of that door too. Mine had a little rust where where the outer door skin is sealed inside under the bottom weather strip. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Vmax540 Posted October 9, 2014 Share Posted October 9, 2014 I'll bet the still plate is double walled and could get condensation between the two layers of steel ? Link to comment Share on other sites More sharing options...
Max Capacity Posted October 9, 2014 Share Posted October 9, 2014 These things are 10 y/o. If you keep after the rust you can stop it early before it gets to bad. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Akasa Posted October 9, 2014 Share Posted October 9, 2014 You just sanded the rusted areas down and applied por? Is that all you need to do? I have a few spots near my sunroof that i'd like to seal. Just looking for advice. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 9, 2014 Share Posted October 9, 2014 Pretty much, that's it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Crazy_Pilot Posted October 9, 2014 Author Share Posted October 9, 2014 You just sanded the rusted areas down and applied por? Is that all you need to do? I have a few spots near my sunroof that i'd like to seal. Just looking for advice. If you research POR-15 you'll see the process. You clean the area, degrease, apply their Metal-Prep treatment (neutralizes any remaining rust and creates a zinc-phosphate coating), and then paint over with the POR-15 paint. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 9, 2014 Share Posted October 9, 2014 I use this stuff called Extend, https://www.google.com/search?q=extend+rust+treatment&rls=com.microsoft%3Aen-us%3AIE-ContextMenu&oe=&safe=active&gws_rd=ssl&oq=&gs_l= 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DonnyJagaru Posted October 9, 2014 Share Posted October 9, 2014 IMO, Krown rustproofing every year should be compulsory in S. Ontario. Its not too late to start with a 2008. Link to comment Share on other sites More sharing options...
Crazy_Pilot Posted October 10, 2014 Author Share Posted October 10, 2014 She's been Krown'd every year since I bought her two years ago. I remove all the plastic under body panels (including the engine one) every time to make sure they cover everything. Link to comment Share on other sites More sharing options...
