K2e2vin Posted October 8, 2014 Share Posted October 8, 2014 I just noticed this problem last week on our way back from a beach trip. We usually have the AC cranked really cold(anywhere from 67-71F). What would happen is after a while, there would be no air coming out of the vents but you can hear the blower still going and the indicator shows the blower at full blast or somewhere near there. After turning it off for a couple minutes, and turning it back on, it would work again. Does anyone know what's going on? Link to comment Share on other sites More sharing options...
KRM Posted October 8, 2014 Share Posted October 8, 2014 maybe the cabin filter? Link to comment Share on other sites More sharing options...
K2e2vin Posted October 8, 2014 Author Share Posted October 8, 2014 I was thinking that but wouldn't it block air all the time? Link to comment Share on other sites More sharing options...
08 LGT Posted October 9, 2014 Share Posted October 9, 2014 This happened in my old Camry. The diagnosis was that a leak somewhere in the air tubes that run to the vents was letting moisture in, which condensed in the tubes. After running the air conditioner for a certain amount of time, this moisture freezes and blocks the tubes up, preventing air from passing through. If the car was left off for several hours, the blockage would melt and air would again be able to pass through, but of course only for a limited time before freezing again. The only way to fix this, if you have the same problem, is to spend a ton of $$$$ to completely rerun all those line from the air compressor to the cabin, since it is impossible to tell where the leak allowing moisture in is. Link to comment Share on other sites More sharing options...
K2e2vin Posted October 9, 2014 Author Share Posted October 9, 2014 Thanks, that makes sense. Before it happens, we have seen "smoke" or condensation blowing from the vents. Link to comment Share on other sites More sharing options...
robinlsb Posted October 9, 2014 Share Posted October 9, 2014 I just noticed this problem last week on our way back from a beach trip. We usually have the AC cranked really cold(anywhere from 67-71F). What would happen is after a while, there would be no air coming out of the vents but you can hear the blower still going and the indicator shows the blower at full blast or somewhere near there. After turning it off for a couple minutes, and turning it back on, it would work again. Does anyone know what's going on? Recharge the AC. There is ice in the AC coils that blocks the air. Even a small amount of refrig loss in the AC can cause this, particularly in high humidity conditions. This is a known problem. When you turn the AC off, the ice blockage melts It's just like a home AC freezing up. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
K2e2vin Posted October 9, 2014 Author Share Posted October 9, 2014 Wouldn't it be the lines(refrigerant) that freeze up and the compressor would cycle(or possibly cause the motor to struggle more)? I've experienced low refrigerant before; it never froze at the heat exchanger but usually the lines to/from the condenser...thus blowing hot air. It should also be noted I had checked the A/C pressures about a month or two ago after I got it back from the shop(using a manifold). Everything looked fine. Link to comment Share on other sites More sharing options...
starionesir Posted October 9, 2014 Share Posted October 9, 2014 Is the condensation drain clean and draining under the car properly will its running? I've seen drains plug up and cause a lot of different issues. Coils are the normal spot for ac to freeze up as well. Seen many freeze up in homes from clogged air filters. Link to comment Share on other sites More sharing options...
KRM Posted October 9, 2014 Share Posted October 9, 2014 after some rethinking this and coming back to the topic, I realized that this happened to an older honda I have. had to recharge the ac and clean out the ductwork in the dashboard. but everyone else beat me to it Link to comment Share on other sites More sharing options...
DonnyJagaru Posted October 9, 2014 Share Posted October 9, 2014 Any A/C will freeze up if the compressor doesn't cycle in very humid weather. Also, I usually have all my windows open traveling to/from the beach. Link to comment Share on other sites More sharing options...
