Bobbo63 Posted October 7, 2014 Share Posted October 7, 2014 New Subaru owner, 1995 legacy outback l with the 2.2 5 speed. 246,000+ miles. Have had it less than a month. I replaced the knock sensor to make the check engine light go out. It worked. The check engine light is currently off, and when im driving it acts like the injectors quit working. and with a blip of the throttle the engine comes back to life. Its expecially noticable when you are deep into the throttle, and let off enough to start decellerating but not completely off. The car acts like its searching for the correct ammount of... "Something" weather it be timing or fuel. but it acts like theres no throttle there at all till the rpms drop enough and it will come back to life. Something tells me it would be the throttle positioning sensor... if the car has one. This is my first subaru, and im already in love. Please help Sharron. Thats her name. Link to comment Share on other sites More sharing options...
Zues Marine Posted October 7, 2014 Share Posted October 7, 2014 Clean out your MAF and IACV.. and then make sure you have no vacuum lines loose Link to comment Share on other sites More sharing options...
Bobbo63 Posted October 7, 2014 Author Share Posted October 7, 2014 what do i use to clean it with? carb cleaner? Link to comment Share on other sites More sharing options...
Tr00b Posted October 7, 2014 Share Posted October 7, 2014 Is the knock sensor at the proper torque? I just did this, tore my engine apart and didn't tighten several grounds or the alt-to battery connection. Would SHUT DOWN at brisk revs over 4000rpm. Would pay to go through the grounds. With an advanced scan tool, you can watch TPS and MAF signals. I use an ELM327 and the Torque bluetooth app on my phone. Link to comment Share on other sites More sharing options...
monkeyposeur Posted October 7, 2014 Share Posted October 7, 2014 Buy a $6 can of MAF cleaner. Don't use anything else. Link to comment Share on other sites More sharing options...
Zues Marine Posted October 8, 2014 Share Posted October 8, 2014 With an advanced scan tool, you can watch TPS and MAF signals. I use an ELM327 and the Torque bluetooth app on my phone. i highly recommend this to everyone!!what a well spent $12.. i adjusted my TPS and high idle in seconds... compared to busting out a multimeter and what not Link to comment Share on other sites More sharing options...
BoxerLove Posted October 8, 2014 Share Posted October 8, 2014 Bobbo63, does it feel like someone taps the breaks for a split second? Link to comment Share on other sites More sharing options...
Tr00b Posted October 8, 2014 Share Posted October 8, 2014 Buy a stack of them like 3 or 4. You can lend them to friends, have one in each vehicle plus a spare etc... and they tend to fry quite a bit. I've burnt up about 4 of them. Link to comment Share on other sites More sharing options...
Bobbo63 Posted October 8, 2014 Author Share Posted October 8, 2014 yeah... taps them or shuts the key off, cause as soon as i move the throttle about 20% of its range it comes right back. Link to comment Share on other sites More sharing options...
Bobbo63 Posted October 8, 2014 Author Share Posted October 8, 2014 will the elm 327 work on a 95? Link to comment Share on other sites More sharing options...
DGR81 Posted October 8, 2014 Share Posted October 8, 2014 will the elm 327 work on a 95? I have a 95 Legacy that has OBD II in it. The port should be next to the steering wheel on the left side. There should be a little compartment that you could take off that is where it is. Link to comment Share on other sites More sharing options...
Bobbo63 Posted October 10, 2014 Author Share Posted October 10, 2014 i know what it looks like... and the location. When i bought it, i had to visit 5 different parts stores to find the correct reader. Finally i pulled into a dealership and threw 20 bucks at a mechanic to tell me what my original code was. Pretty sure all parts stores told me i had the obd1. Whats the difference? I think the elm327 is pretty friggin sweet. If i got the obdII im buyin one! Link to comment Share on other sites More sharing options...
twisty Posted October 14, 2014 Share Posted October 14, 2014 yes it does. i have a 95 wagon and mine works just fine. the 95 is truly obd2, but it doesnt have every feature available like a newer obd2 car does, is all. the important stuff is there tho. Link to comment Share on other sites More sharing options...
Zues Marine Posted October 14, 2014 Share Posted October 14, 2014 yeah idk how many times ive had to argue with the oreillys counter guy that my 95 IS OBD2... and just give me what i want. [ame=http://www.amazon.com/iSaddle-Bluetooth-CAN-BUS-Diagnostic-Windows/dp/B008U1MOM8/ref=sr_1_1?ie=UTF8&qid=1413310936&sr=8-1&keywords=elm+327]Amazon.com: iSaddle Super Mini ELM327 V1.5 OBD2 OBD-II Bluetooth CAN-BUS Auto Diagnostic Tool for Windows & Android Torque (Blue Color): Automotive[/ame] Link to comment Share on other sites More sharing options...
Bobbo63 Posted October 15, 2014 Author Share Posted October 15, 2014 thanks boxter brethrens... i already love this forum! Link to comment Share on other sites More sharing options...
