MatteLegacy25 Posted October 6, 2014 Share Posted October 6, 2014 I'm having issues with my legacy. No check engine light on but its got a lot of lag. I can put it to the floor and it just bogs down and won't get up and go. Kind of chugs a little bit. if im in first gear and get after it seems ok to a point. Any suggestions on what the problem might be? Turbo? plugged cat? misfiring cylinders? Link to comment Share on other sites More sharing options...
MrTris Posted October 6, 2014 Share Posted October 6, 2014 I'm having issues with my legacy. No check engine light on but its got a lot of lag. I can put it to the floor and it just bogs down and won't get up and go. Kind of chugs a little bit. if im in first gear and get after it seems ok to a point. Any suggestions on what the problem might be? Turbo? plugged cat? misfiring cylinders? If you're all stock and have a misfire or a clogged cat, you'll likely have a CEL to go with 'em. My guess is that your turbo is on its way out. Has it been replaced before? Link to comment Share on other sites More sharing options...
MatteLegacy25 Posted October 7, 2014 Author Share Posted October 7, 2014 I've got a cat back exhaust and a k&n air intake on it. And yes the turbo has been replaced before. The whole motor has actually been rebuilt about 3 years ago and I believe they put a mittsubishi turbo in it because they said the bearings were better or something. Just started giving me issues a few months ago. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 7, 2014 Share Posted October 7, 2014 Where are you located ? There may be a tuner close to you. Can you down load some data from the car ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MatteLegacy25 Posted October 8, 2014 Author Share Posted October 8, 2014 Im in Vermont. I had my buddy who owns a car garage hook up is OBD computer to it and nothing came up as being off. how would i go about downloading data from the car? Oil has been checked and is good. running AMSOil Synthetic. Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted October 8, 2014 Share Posted October 8, 2014 Clean the MAF and reset the ecu... Get more info on that turbo.. maybe you need a tune.. Pull DP and check for shaft play Link to comment Share on other sites More sharing options...
MatteLegacy25 Posted October 9, 2014 Author Share Posted October 9, 2014 Ok i will check that! Thanks Link to comment Share on other sites More sharing options...
MatteLegacy25 Posted October 9, 2014 Author Share Posted October 9, 2014 Whats the best thing to use to clean the MAF? Link to comment Share on other sites More sharing options...
Nightmaresmk Posted October 9, 2014 Share Posted October 9, 2014 maf cleaner Link to comment Share on other sites More sharing options...
ragman Posted October 9, 2014 Share Posted October 9, 2014 If you have an aftermarket turbo, a catback, and a cold air intake....all on the stock tune, could be quite possible your IAM is below 1, which pulls timing and makes it run like its in safe mode. Basically, you need to run a tune with those aftermarket parts. Link to comment Share on other sites More sharing options...
MatteLegacy25 Posted October 10, 2014 Author Share Posted October 10, 2014 Cleaned the o2 sensor and that made a huge difference! Woke the car up big time. Link to comment Share on other sites More sharing options...
