HFT_Eliot Posted October 2, 2014 Share Posted October 2, 2014 So I am going to be getting a protune soon and I was thinking that I might as well get a electronic boost controller. I am worried that it will put too much stress without supporting parts. I already have a turboback exhaust. So what do people suggest for supporting stuff? Also what boost is safe to run on stock internals? Thanks! Link to comment Share on other sites More sharing options...
Rhitter Posted October 4, 2014 Share Posted October 4, 2014 An EBCS is not needed on Stage 1 (just a tune) or Stage 2 (downpipe) tunes. That said I have one because it gives the tuner a little greater control over the tune, but you won't see higher numbers because of it. The "supporting" mod that's basically required is the Bulletproof mod for the stock intercooler. The end tanks can separate at even stock levels. http://legacygt.com/forums/showthread.php/bulletproof-tmic-mod-lgt-08-wrx-158870.html My OBXT build Link to comment Share on other sites More sharing options...
scoobyscoodle Posted October 4, 2014 Share Posted October 4, 2014 An EBCS will not put any more or less stress on anything. However, running an EBCS before/without a custom tune in impossible. The proper boost levels and fuel maps will be decided by your tuner. Link to comment Share on other sites More sharing options...
