Rhitter Posted January 18, 2016 Share Posted January 18, 2016 I need an exhaust, mine sounds so boring compared to that.... although I have very very few roads where I can floor it like you are. My OBXT build Link to comment Share on other sites More sharing options...
LatentWagen Posted January 20, 2016 Author Share Posted January 20, 2016 Some throwback pics of my previous Subarus: http://legacygt.com/forums/attachment.php?attachmentid=223214&stc=1&d=1453326870 http://legacygt.com/forums/attachment.php?attachmentid=223379&stc=1&d=1453567152 http://legacygt.com/forums/attachment.php?attachmentid=223380&stc=1&d=1453567152 Black WRX was from '02 to '05, blue from '06 to '07, and silver from '08 to '12. Not pictured are a Silverthorne '00 RS coupe, two '95 Legacy L sedans, and a '94 Impreza L sedan LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
LatentWagen Posted February 19, 2016 Author Share Posted February 19, 2016 Nice pic from the last Tri-State drive up to the Hawk's Nest: http://legacygt.com/forums/attachment.php?attachmentid=225062&stc=1&d=1455903881 Also cleaned up and re-DEI'd my intercooler, because spaceship: http://legacygt.com/forums/attachment.php?attachmentid=225063&stc=1&d=1455903881 http://legacygt.com/forums/attachment.php?attachmentid=225064&stc=1&d=1455903881 LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
LatentWagen Posted March 16, 2016 Author Share Posted March 16, 2016 Winters are on. Still deciding whether I'll take the lip off, or if the first snowbank will. http://legacygt.com/forums/attachment.php?attachmentid=222065&stc=1&d=1451497856 Shortest Winter season ever. Lip made it through unscathed! http://legacygt.com/forums/attachment.php?attachmentid=226609&stc=1&d=1458168397 LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
GipsySpec.B Posted March 17, 2016 Share Posted March 17, 2016 Some throwback pics of my previous Subarus: http://legacygt.com/forums/attachment.php?attachmentid=223379&stc=1&d=1453567152 That blue WRX's stance is PERFECT. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
LatentWagen Posted March 17, 2016 Author Share Posted March 17, 2016 Thanks! It was on Tein Flex w/EDFC. Miss that OEM body kit the most. That pic is from over 10 years ago LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
Shipman Posted March 18, 2016 Share Posted March 18, 2016 Quite impressive bugs. Link to comment Share on other sites More sharing options...
LatentWagen Posted March 26, 2016 Author Share Posted March 26, 2016 My driver's side rear endlink (AVO adjustable) gave up a few threads and wouldn't stay together, so I found a used pair of AVO 70mm solid ones on fleaBay for 80 bucks. Having had one AVO link fail already, it probably wasn't the wisest move, but, fixed for now (will eventually go KartBoy). Job took 10 minutes, for once! http://legacygt.com/forums/attachment.php?attachmentid=227165&stc=1&d=1459022624 So nice to have that rear sway bar back in play, the car is on rails again Also made the switch to the taller Tokyo Roki Mazda RX-8 oil filter (PN# N3R1-14-302), definitely a sturdier bit than the FRAM-supplied OE Subaru blue. More filter area is a good thing, too! LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
jasejase Posted March 26, 2016 Share Posted March 26, 2016 They almost look a little torqued... Are you supposed to use spacers like with the KB's? Link to comment Share on other sites More sharing options...
LatentWagen Posted March 26, 2016 Author Share Posted March 26, 2016 They went right in, and are vertical when the car is on the ground, instead of perched up on the flat-laying wheels. Doesn't seem like they're preloaded... LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
jasejase Posted March 26, 2016 Share Posted March 26, 2016 Nice ramps! Link to comment Share on other sites More sharing options...
LatentWagen Posted March 26, 2016 Author Share Posted March 26, 2016 Run what you brung! LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
snm95ls Posted March 26, 2016 Share Posted March 26, 2016 Nice ramps! I bet those could make for some sweet jumps. Link to comment Share on other sites More sharing options...
jasejase Posted March 26, 2016 Share Posted March 26, 2016 I bet those could make for some sweet jumps. Heck yes! Link to comment Share on other sites More sharing options...
LatentWagen Posted April 14, 2016 Author Share Posted April 14, 2016 It was the Saabaru's turn for some attention today... finally took off the stock wheels and all-seasons that came with the car. They were a little chewed up, so the BBS made a nice difference, visually. Going from A/S tires to Conti DW was also nice http://legacygt.com/forums/attachment.php?attachmentid=228226&stc=1&d=1460674438 Also changed the engine oil ('tella & RX8 Toyo), and gear oil. Now running M1 Delvac 75w90... it's amazing in both the spec B's 6MT and the Saabaru/LGT 5MT. BOTIG threads say that the composition of this oil is closest to the original Subaru Extra-S. I believe it, both gearboxes feel really good after changing over. Can't recommend it enough. Another thing, I'd like to extend a heartfelt thank you to the weather on the NW coast, and the previous owners for garaging this car, because for a 2006, it's pretty darn clean under there: http://legacygt.com/forums/attachment.php?attachmentid=228227&stc=1&d=1460674438 LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
jasejase Posted April 14, 2016 Share Posted April 14, 2016 Nice jack Link to comment Share on other sites More sharing options...
LatentWagen Posted April 15, 2016 Author Share Posted April 15, 2016 JEGS Respect the dual piston action LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
snm95ls Posted April 15, 2016 Share Posted April 15, 2016 JEGS Respect the dual piston action Because NASCAR... Yes I know they are primarily involved in drag racing. Link to comment Share on other sites More sharing options...
LatentWagen Posted April 15, 2016 Author Share Posted April 15, 2016 Judging by my tire-changing speed, I wouldn't make it too long on a NASCAR pit crew... but the jack does the job. It was 30 bucks cheaper than the nearest competition (all the same low-profile aluminum jack, just with different brand names), AND you can order a seal rebuild kit from JEGS for cheap. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
snm95ls Posted April 15, 2016 Share Posted April 15, 2016 Judging by my tire-changing speed, I wouldn't make it too long on a NASCAR pit crew... but the jack does the job. It was 30 bucks cheaper than the nearest competition (all the same low-profile aluminum jack, just with different brand names), AND you can order a seal rebuild kit from JEGS for cheap. Really? That's pretty damn awesome. Might have to add that one to the collection. One can never have too many floor jacks. Link to comment Share on other sites More sharing options...
Smithcraft Posted April 16, 2016 Share Posted April 16, 2016 I don't care what they say about you LW, this thread is inspiring! SC 1994 Legacy MI 2008 Legacy GT specB 2023 Crosstrek Limited Link to comment Share on other sites More sharing options...
battelready Posted April 16, 2016 Share Posted April 16, 2016 I don't care what they say about you LW, this thread is inspiring! SC Inspiring indeed. I have everything he had minus the spec b portion. I bought an auto be more involved in my uninvolvedness . 200k+ Club If you can't blind them with brilliance, baffle them with bullshit. My high mileage turd. Link to comment Share on other sites More sharing options...
LatentWagen Posted April 26, 2016 Author Share Posted April 26, 2016 Here are a few pics from Sunday's C&C. Brought the real camera this time; still learning how to use it! http://legacygt.com/forums/attachment.php?attachmentid=229049&stc=1&d=1461632415 http://legacygt.com/forums/attachment.php?attachmentid=229055&stc=1&d=1461632415 http://legacygt.com/forums/attachment.php?attachmentid=229052&stc=1&d=1461632415 http://legacygt.com/forums/attachment.php?attachmentid=229056&stc=1&d=1461632415 Yea, my paint REALLY needs some love. And BB-V also showed up at the end, with his monster truck LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
battelready Posted April 26, 2016 Share Posted April 26, 2016 I love that m6 . Ive been looking months for a clean one. I bought an auto be more involved in my uninvolvedness . 200k+ Club If you can't blind them with brilliance, baffle them with bullshit. My high mileage turd. Link to comment Share on other sites More sharing options...
LatentWagen Posted April 26, 2016 Author Share Posted April 26, 2016 I love that m6 . Ive been looking months for a clean one. Was talking to that guy for a while, he brought his dad along with him. The car was awesome, one of my all time faves. His buddy brought his early 90's MB E500, which I didn't get a good pic of. Another favorite! LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
