jackal8788 Posted September 23, 2014 Share Posted September 23, 2014 Dyno Tune: The Franz (Late Model Throttle) makes 332 whp on a 2.5L + BNR20G @ 23.5psi Event: Dyno Tune Loaction: Late Model Throttle Date: 08/14/2014 Ambient Temp: 82F Elevation: 873' Weather: Clear Car: 2010 Legacy GT Tuner: The Franz, Late Model Throttle Dyno Info: Dynojet Transmission: 6MT Gear: 3rd Peak Horse Power at RPM: 332 @~5300 Peak Torque at RPM: 380@ ~3600 Baseline hp/tq for a stock on same dyno: Unknown Target Boost: 23.5 Target AFR: 11.9 (lambda 0.81 = 7.82 for E85) Engine/Power Modifications: BNR 20G/TD05 VF54 turbo, RacerX charge pipe, Turbosmart Kompact BPV, RacerX TMIC, ID1000 injectors, DW300 fuel pump, Invidia catless DP, stock CBE, KS73mm MAF housing, AEM Dryflow filter, Perrin throttle body inlet hose, NKG iridium 1 step colder plugs Driveline Modifications:ACT HDSS clutch, WRX short throw shifter Suspension Modifications: H&R springs, 19mm RSB VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
jackal8788 Posted September 23, 2014 Author Share Posted September 23, 2014 Here's a link to a video of the final pull: https://www.youtube.com/watch?v=kWEK-AGnow0&feature=youtu.be VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
fahr_side Posted September 23, 2014 Share Posted September 23, 2014 Nice results! Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
jackal8788 Posted September 23, 2014 Author Share Posted September 23, 2014 Thanks you sir! For my DD, it has made the ride to and from work much more enjoyable. VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
ragman Posted September 23, 2014 Share Posted September 23, 2014 Just curious...for a target of 11.1, it sure seems you are more like 11.9 during alot of that pull. Was that leaner AFR planned? Link to comment Share on other sites More sharing options...
jackal8788 Posted September 23, 2014 Author Share Posted September 23, 2014 ^My mistake. I typed it wrong in my initial post. Target was 11.9 as the plot shows. Nice catch! VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
