Mindflux Posted September 22, 2014 Share Posted September 22, 2014 I've got an 06 LGT with 78K on the clock. It was originally sold 12/05. So that means we're at 8 years and 10 months. I know the interval is 105,000 or 105 months. Since there is no inspection window on the t-belt cover I can only assume I'm on borrowed time at this point? I see the preferred hardware is a gates kit. Is the gates kit with the thermostat OK or is that t-stat junk? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 22, 2014 Share Posted September 22, 2014 Age is a facture. You'll want to think about replaceing it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Mindflux Posted September 22, 2014 Author Share Posted September 22, 2014 Proof every car should be chained. Age should not be a factor for something this critical Link to comment Share on other sites More sharing options...
JJr Posted September 22, 2014 Share Posted September 22, 2014 05 here, 91k, purchased 6/05, will be getting mine done within 2 months, 6-8 months overdo:eek: have gates kit, OEM WP, thermo and gates radiator hoses ready to go any parts I'm missing? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 22, 2014 Share Posted September 22, 2014 Oh FWIW, I also replace both radiator caps on my 05 last year. Inspect the rubber seals, if they look aged, its $20.00 well spent. Also check out both drive belts, PS and Alternator. I replaced them when I did the T belt years ago. Check out the engine ground wires that go to the bottom of both heads, I replaced them also. Age takes its toll... winters coming... how's your battery ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JJr Posted September 22, 2014 Share Posted September 22, 2014 Sorry I forgot, I have Gates drive belts too! Original battery last year. Thx Max, I'll check the ground wires and caps:) Link to comment Share on other sites More sharing options...
Max Capacity Posted September 22, 2014 Share Posted September 22, 2014 How is the coolant crossover tube that feeds the oil cooler ? Is it all rusty ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GTTuner Posted September 22, 2014 Share Posted September 22, 2014 I've seen guys go 140K on the belt and it looks great when I change it out. Don't panic but get it done before the cold weather sets in. Link to comment Share on other sites More sharing options...
JJr Posted September 22, 2014 Share Posted September 22, 2014 How is the coolant crossover tube that feeds the oil cooler ? Is it all rusty ? Car has been on the west coast it's whole life, not a touch of rust anywhere! I take that back, I did pull my battery hold down and Dremel some surface rust off it and paint it recently. Under the car looks fantastic, but I'll check that tube out too ( I think I read the thread on that one). Thx again for the input Max. Link to comment Share on other sites More sharing options...
parad1mg Posted September 22, 2014 Share Posted September 22, 2014 Since there is no inspection window on the t-belt cover. Side timing belt covers are easily removable. Use a flashlight and a mechanics inspection mirror. Gates timing belt kit with OEM waterpump and OEM thermostat. Replaced mine at 112k and all the idler pulleys had bad bearings. Timing belt itself was still in great shape. The car ran so much quieter and smoother with the new pulleys. I also replaced both radiator hoses, oil cooler seal, LWCP (didn't make a difference with my 5eat), installed a stand alone trans cooler, m/t radiator, changed the oil, cleaned the crank/cam sensors and generally check everything I can get my hands on. Link to comment Share on other sites More sharing options...
sunny5280 Posted September 22, 2014 Share Posted September 22, 2014 Car has been on the west coast it's whole life, not a touch of rust anywhere! I take that back, I did pull my battery hold down and Dremel some surface rust of it and paint it recently. Under the car looks fantastic, but I'll check that tube out too ( I think I read the thread on that one). Thx again for the input Max. I'm happy I live in a, relatively speaking, rust free state too. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 22, 2014 Share Posted September 22, 2014 If you do it yourself, make sure you have the right clearance between the guides and the belt (IIRC, 1mm+/- 0.5mm). If not, it may cost you an engine... Link to comment Share on other sites More sharing options...
Mindflux Posted September 23, 2014 Author Share Posted September 23, 2014 Side timing belt covers are easily removable. Use a flashlight and a mechanics inspection mirror. Replaced mine at 112k and all the idler pulleys had bad bearings. Timing belt itself was still in great shape. Do you have a howto on the side covers? Also at 112K but what age? Link to comment Share on other sites More sharing options...
parad1mg Posted September 23, 2014 Share Posted September 23, 2014 10 mm bolts and they'll come right off. Just undo the bolts and slide them down. Download the vacation pics to see where the bolts are. My t-belt was 7 years old. Link to comment Share on other sites More sharing options...
Mindflux Posted September 23, 2014 Author Share Posted September 23, 2014 Download the vacation pics to see where the bolts are. My t-belt was 7 years old. It seems the vacation pics download is dead. Link to comment Share on other sites More sharing options...
Akasa Posted September 23, 2014 Share Posted September 23, 2014 My timing belt in my 05 GT with 87k on the clock has nearly 10 years on it at this point, belt looks fine, but i'll be replacing it soon as well, before winter. I have also seen people go past 105k miles without issues, though I don't recommend that. I wouldn't be stressing on changing your belt /immediately/, but just get around to is some time this year. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 23, 2014 Share Posted September 23, 2014 It seems the vacation pics download is dead. http://people.csail.mit.edu/ilh/vacation/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Mindflux Posted September 23, 2014 Author Share Posted September 23, 2014 http://people.csail.mit.edu/ilh/vacation/ Thanks. No 2006? I assume the 2005 pics are still fun to look through? Link to comment Share on other sites More sharing options...
Mindflux Posted September 23, 2014 Author Share Posted September 23, 2014 My timing belt in my 05 GT with 87k on the clock has nearly 10 years on it at this point, belt looks fine, but i'll be replacing it soon as well, before winter. I have also seen people go past 105k miles without issues, though I don't recommend that. I wouldn't be stressing on changing your belt /immediately/, but just get around to is some time this year. Right. Well I don't run the car full throttle anywhere either, and from what I was told about the previous owner being a middle aged fella (if that's true) I don't think he did either. So the belt is probably in fine shape aside from some age on it. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 23, 2014 Share Posted September 23, 2014 Still, it is really easy to take the side cover off for a quick inspection. It'll take 10mn of your time max (assuming the 10mm bolts are not stuck). I'll try to provide a picture if you don't know where these covers are. Link to comment Share on other sites More sharing options...
Mindflux Posted September 23, 2014 Author Share Posted September 23, 2014 Still, it is really easy to take the side cover off for a quick inspection. It'll take 10mn of your time max (assuming the 10mm bolts are not stuck). I'll try to provide a picture if you don't know where these covers are. I'd appreciate that. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 23, 2014 Share Posted September 23, 2014 Thanks. No 2006? I assume the 2005 pics are still fun to look through? They are the same. Just make sure your in the right section. DOHC GT's start around page 1650, also check out the back of the book for, how things work. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 23, 2014 Share Posted September 23, 2014 They are the same. Just make sure your in the right section. DOHC GT's start around page 1650, also check out the back of the book for, how things work. +1. I used these very sections to replace my timing belt and pulleys on my 06 two weeks ago. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 23, 2014 Share Posted September 23, 2014 Still, it is really easy to take the side cover off for a quick inspection. It'll take 10mn of your time max (assuming the 10mm bolts are not stuck). I'll try to provide a picture if you don't know where these covers are. See my click here link, there are pictures in there of the covers. Oh, if you believe the car was never driven hard...I have a bridge, in NYC you may be interested in. I'll be 60y/o in a couple weeks. My cars never get driven hard either... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 23, 2014 Share Posted September 23, 2014 I'll be 60y/o in a couple weeks. My cars never get driven hard either... Link to comment Share on other sites More sharing options...
