Max Capacity Posted September 17, 2014 Share Posted September 17, 2014 While driving on the highway, I just changed lanes in morning traffic, doing lbetween 60 and 65mph when the tranny popped out of 5th gear. I finished the 6 miles to work in 4th gear, 60mph. It seems the tranny won't go into 3rd gear either, it will go into 1st, 2nd, when you shift towards 3rd it goes into 5th. I can go 1,2,4. Also have reverse. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted September 17, 2014 Author Share Posted September 17, 2014 (edited) Drove the car home on the back roads. 1st - 4th work fine. Fluid was a little grayish when I check it before I came home. I'll pull it over the next few day's. 5th is the gear at the left end of the "driven shaft" that is that pinon gear on the front diff. Behind that square flange with is a roller bearing. http://i185.photobucket.com/albums/x40/92Si/DSCN5295_zps3025c9b3.jpg Edited September 17, 2014 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ragman Posted September 17, 2014 Share Posted September 17, 2014 What can I say! You should have bought a 5EAT, lol Sorry man, that sucks. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 17, 2014 Author Share Posted September 17, 2014 Na, should have done the 6 speed swap years ago. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
heiche Posted September 18, 2014 Share Posted September 18, 2014 that specific 5mt of yours must be haunted. it's had quite a few rebuilds? BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
Max Capacity Posted September 18, 2014 Author Share Posted September 18, 2014 Yes, its had 3 different techs work on it over the years. The dealer did the first two rebuilds, a trusted tranny shop did one and my buddy who was a tranny tech by trade for many years the last 4 times. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Hepy117 Posted September 18, 2014 Share Posted September 18, 2014 Learn to drive stick Only jokin of course. 6speed time! Link to comment Share on other sites More sharing options...
Max Capacity Posted September 18, 2014 Author Share Posted September 18, 2014 Yea, I know what your saying, I've only been driving stick all my life, I'll be 60y/o next month, so its not like I'm new at this. I have to wonder if the LWFW has anything to do with all the issues ? My Spec B's tranny is so much quieter. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GEE-OTTO Posted September 18, 2014 Share Posted September 18, 2014 Yea, I know what your saying, I've only been driving stick all my life, I'll be 60y/o next month, so its not like I'm new at this. I have to wonder if the LWFW has anything to do with all the issues ? My Spec B's tranny is so much quieter. Case flex perhaps? I wouldnt rebuild that gearbox in that case, esp if the layshaft bearings are all intact and damage free. Sure you have a plan in place just dont got straight cut I know @ 60 you may be thinking about uber street Link to comment Share on other sites More sharing options...
Max Capacity Posted September 18, 2014 Author Share Posted September 18, 2014 My son asked about case flex too ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
heiche Posted September 18, 2014 Share Posted September 18, 2014 I've heard that case flex is more of an issue with older wrx models, but the lgt isn't really prone to it. BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
Max Capacity Posted September 18, 2014 Author Share Posted September 18, 2014 Mine is a early car, May 04 build date. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AMileHighLGT Posted September 18, 2014 Share Posted September 18, 2014 (edited) Need to do some blast plates if you're pulling it apart again. these help eliminate the case flex and provide a better mesh between gears. found the thread on nastycock. http://forums.nasioc.com/forums/showthread.php?t=2341424 a guy in our local subie club just had a build on a 14 rex, 700 horse through the 5mt Edited September 18, 2014 by AMileHighLGT link Link to comment Share on other sites More sharing options...
whitetiger Posted September 18, 2014 Share Posted September 18, 2014 this happend to me a while back. 5th gear actually split in 2 and fell of the shaft. eventually the rest of the gears slid and it jammed up the shift forks and i couldn't get any gears. Mine was also a 04 build date trans. Link to comment Share on other sites More sharing options...
boxkita Posted September 18, 2014 Share Posted September 18, 2014 I had an early build date 5mt. 5th gear teeth lost their temper and starting chipping off. Once it was out, you could flick the teeth off with your finger. That was after 3rd gear rebuild 30k miles ago. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Max Capacity Posted September 18, 2014 Author Share Posted September 18, 2014 Need to do some blast plates if you're pulling it apart again. these help eliminate the case flex and provide a better mesh between gears. found the thread on nastycock. http://forums.nasioc.com/forums/showthread.php?t=2341424 a guy in our local subie club just had a build on a 14 rex, 700 horse through the 5mt Thanks for the link, looks like a good product. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted September 20, 2014 Author Share Posted September 20, 2014 Tranny's out. off to a barbecue now. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
heiche Posted September 20, 2014 Share Posted September 20, 2014 ur quick! BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
Max Capacity Posted September 21, 2014 Author Share Posted September 21, 2014 (edited) Thanks, Well it's not like I didn't start 3 evenings ago. But it's getting dark earlier. I had it ready to slide off the guide pins in just over 3 hours. I had the lower ball joints out, Wed and Thursday nights. I played the left lower and got it out of the spindle, covered it and the pinch pin with anti-seize and put it back in the spindle. Thinking about doing the same with the right. Today I removed the center heat shield. well cut off the rusty bolts and tabs, then DEI heat wrapped it. Hopefully that was the rattle I've been having.Also have a leaking read diff mount, thinking about ordering one and than having it replaced, One of the nuts is a bit rounded. I sprayed it with Aero-Kroil we'll see if my impact and universal can break it loose. I recall having trouble with it when I put the rear diff in a few years back. Just put the old tranny in the back of the Spec, in the spare tire well with cardboard and some wood blocks. I'll pick up a used tranny with 97,000 miles on it tomorrow. As I was rolling the tranny getting all the fluid out, I heard clinking inside. The drain plug had 1/4" x 1/2" long, about 1/8" thick metal piece on it. I'm done with this tranny. Edited September 21, 2014 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AMileHighLGT Posted September 21, 2014 Share Posted September 21, 2014 Used 6 speed? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 21, 2014 Author Share Posted September 21, 2014 No that's to much money to spend on a car this old. The Moore Performance Blast Plate might be a good idea. On side note, the turbo with 55,000 miles at 21psi has no shaft play. I had to remove the three mount bolts to get the tranny past it, glad I bolt the turbo to the up pipe. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
heiche Posted September 21, 2014 Share Posted September 21, 2014 you certainly gave the original trans more than enough chances. your new-to-you 5mt has got to be better! BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
Max Capacity Posted September 21, 2014 Author Share Posted September 21, 2014 Yes, that's what we're thinking. I think the smart thing to do is have it opened up and checked out to make sure the synchro's are in good shape. It coming from a junkyard, oh sorry, a recyclers. My tranny guy is on vacation so I'll have to wait a week for him to come back. I can finish a few other projects around the house in the mean time. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted September 24, 2014 Author Share Posted September 24, 2014 I just ordered the Moore Blast Plates. I'll do a review over the next few months. Dropped the tranny off at Eastwoods machine shop so my tranny guy can open it up and make sure its ok. I also got the rear diff cradle out of the car. One of the bushings was leaking. I ordered the Whiteline KDT905 from underdog Monday, got that and front sway bar bushing from him today. Had a tough time with the nut and bolt on the passenger side of the cradle. A few spray's of Aero Kroil and a few day's seems to do the trick. I had to hit it off/on direction with the 1/2 impact gun a while, the socket got hot, but after a few times of on/off direction, the nut spun off and bolt just pushed out. I'll have Eastwoods Auto Machine press out the old bushings. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AMileHighLGT Posted September 24, 2014 Share Posted September 24, 2014 This is good news. I'm an auto guy. Too much stop and go for a stick. I have a real hard time believing what everyone says about the 5mt being junk. Its not like your pushing an ungodly amount of power and torque through the gearset. I am really excited for you max -I hope these blast plates work out for you. Link to comment Share on other sites More sharing options...
