specbgt08 Posted September 15, 2014 Share Posted September 15, 2014 Hey everyone, When I got in my car the other day and had the keys in the on position I was listening to the stereo and it just randomly stopped playing sound and made a few clipping noises. Also, the actual stock headunit was making noises like it was trying to change a cd...but I was listening to FM radio. Everything is stock. Later when I got back into the car everything was normal. Just wondering if anyone knows what might be the issue. Thanks Link to comment Share on other sites More sharing options...
Destric Posted September 26, 2014 Share Posted September 26, 2014 i had the same issue, on my case it was the headunit, so i had to replace it; but you can check the cables to the speaks sometimes the unit goes into a safe mode for protection if there is any circuit. Link to comment Share on other sites More sharing options...
specbgt08 Posted September 26, 2014 Author Share Posted September 26, 2014 thanks, so far its only done it once and never again yet, we shall see. Link to comment Share on other sites More sharing options...
Akasa Posted September 27, 2014 Share Posted September 27, 2014 Might as well check both ground straps on the under body of the car, either side of the engine. Passenger is to the exhaust manifold right in front of the AFR sensor. I've heard some really funky things happening if they're not there. Attached is a picture of where it is, there should be another strap on the other side of the engine. Yours will NOT look identical to this. Mine was broken, so I made this as a replacement really quick. http://i.imgur.com/hN3qTlp.jpg Link to comment Share on other sites More sharing options...
