Fenix_guyver Posted September 15, 2014 Share Posted September 15, 2014 I am going to put an STi cluster in my BD but want to know how to wind it forward to match mine. What options are there? I know this is not the spot to ask but don't want to join nasioc just to ask the question. Link to comment Share on other sites More sharing options...
johnegg Posted September 16, 2014 Share Posted September 16, 2014 if you remover the speedo from the cluster, and you ''pop'' up one end of the ''locking'' rod, the left end for ''thousands'', on the top front of the speedo, just above the numbers, you can then rotate the ''unlocked'' numbers forward ( or back) until you get to where you need to be. i suggest you NOT try to get it exact, but you can get it close, within about 5k or so. then snap the ''locking'' rod back in place. try and make sure all numbers are centered equally in the display before you lock them down. Link to comment Share on other sites More sharing options...
Fenix_guyver Posted September 16, 2014 Author Share Posted September 16, 2014 Awesome, you are the man! Link to comment Share on other sites More sharing options...
johnegg Posted September 16, 2014 Share Posted September 16, 2014 PS: the speedo needle is VERY fragile. and almost impossible to replace and get an accurate speedo. Link to comment Share on other sites More sharing options...
Stevo F Posted September 16, 2014 Share Posted September 16, 2014 PS: the speedo needle is VERY fragile. and almost impossible to replace and get an accurate speedo. Yes, the gauge needles tend to get more brittle with age. I had to glue the one back together on my '88 Nissan 'speedo after I broke it. Link to comment Share on other sites More sharing options...
