magnusonsubie Posted September 29, 2014 Share Posted September 29, 2014 Hmmm I hooked up a guage to it and it seemed high. So my be it is a clogged TXV. Do you know how to tear into that? Possibly this weekend? 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
GTEASER Posted September 29, 2014 Share Posted September 29, 2014 In the '03 it was a completely PITA job, took 2 days. Not sure about the '05. Do you have a FSM for the car? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
magnusonsubie Posted September 29, 2014 Share Posted September 29, 2014 Fsm? 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
magnusonsubie Posted September 29, 2014 Share Posted September 29, 2014 Nevermind figured that out. I have a pdf of the manual 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
Rhitter Posted September 29, 2014 Share Posted September 29, 2014 Fsm? FSM - Factory Service Manual. Berkeley seems to stay about 10 degrees cooler than most other areas in the bay. If it's around 80 - it's too hot. 50-65 is perfect. My OBXT build Link to comment Share on other sites More sharing options...
GTEASER Posted September 29, 2014 Share Posted September 29, 2014 Nevermind figured that out. I have a pdf of the manual I can take a look at it at the meet. Sometimes the expansion valve can be taken out the "easy" way, which is different from the "extremely hard" FSM way which in my '03 according to Subaru I had to remove the dashboard and steering column. I did not do it that way, and even after I did it my way, I found a far easier way which would have save me a whole day. But I have to see the car. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
magnusonsubie Posted September 29, 2014 Share Posted September 29, 2014 I can take a look at it at the meet. Sometimes the expansion valve can be taken out the "easy" way, which is different from the "extremely hard" FSM way which in my '03 according to Subaru I had to remove the dashboard and steering column. I did not do it that way, and even after I did it my way, I found a far easier way which would have save me a whole day. But I have to see the car.  Alright sounds good. Hopefully there is an easy way. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
LegAC_GT Posted September 29, 2014 Author Share Posted September 29, 2014 You might just have low refrigerant. engaging and disengaging of the compressor clutch is usually that. Link to comment Share on other sites More sharing options...
Rhitter Posted September 30, 2014 Share Posted September 30, 2014 Anyone have a compression or leakdown test kit? Mostly just curious how my engine is doing. My OBXT build Link to comment Share on other sites More sharing options...
Chris GTO TT Posted September 30, 2014 Share Posted September 30, 2014 Anyone have a compression or leakdown test kit? Mostly just curious how my engine is doing. I have a compression test kit but not a leak down test kit. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
fredrik94087 Posted September 30, 2014 Share Posted September 30, 2014 I have a compression test kit but not a leak down test kit. DUUUDE...that would be really helpful to me. I am down at least 3whp since I started tracking the car. My guess is the beating is taking some toll. Would be great to know everyting is solid. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Chris GTO TT Posted September 30, 2014 Share Posted September 30, 2014 I'll see if I can make it down on Sunday it's just a long drive for me... 3 hours each way. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
fredrik94087 Posted September 30, 2014 Share Posted September 30, 2014 I'll see if I can make it down on Sunday it's just a long drive for me... 3 hours each way. Yikes...in that case, don't sweat it just for me. It would be nice to know, but I don't even know how long or complicated the entire process will be. Cheers! "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
GTEASER Posted October 1, 2014 Share Posted October 1, 2014 Gotta pull the plugs and screw the compression test hose in to the head at each plug location, crank the motor, take the reading and on to the next cylinder. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
fredrik94087 Posted October 1, 2014 Share Posted October 1, 2014 Gotta pull the plugs and screw the compression test hose in to the head at each plug location, crank the motor, take the reading and on to the next cylinder. Yeah, it sounds like a lot of work. Sounds like a good time to change the spark plugs as well? I may do this in the spring. That may also be a reason why I am down a tad. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Rhitter Posted October 1, 2014 Share Posted October 1, 2014 hmm - if you have to pull the plugs might as well replace them. Not sure I want to do that this weekend.  I think with radiator, rear springs, and maybe endlinks that's probably all I want to do. I keep reading about how terrible the plugs are to change. My OBXT build Link to comment Share on other sites More sharing options...
magnusonsubie Posted October 1, 2014 Share Posted October 1, 2014 Straightened out the bend in the Borla ddman sold me so I will be installing that this weekend as well as hids in both low beams and fogs. Hopefully my AC will be something easy to fix 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
LegAC_GT Posted October 1, 2014 Author Share Posted October 1, 2014 Spark plugs are easy, just takes patience. Link to comment Share on other sites More sharing options...
fredrik94087 Posted October 1, 2014 Share Posted October 1, 2014 I do have some bushings I'd love to install. I would also like to cut out the rest of the plastic next to my fog lights and put wire mesh. Already have it. Just not sure if I will do any of these or just hang out. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
kzr750r1 Posted October 1, 2014 Share Posted October 1, 2014 Spark plugs are easy, just takes patience. And the peeling of things out of the way. 10lb of poo in the 5 lb bag. Gotta love it. Just having a few options for swivel and the right extension/plug socket makes a world of difference. Link to comment Share on other sites More sharing options...
Chris GTO TT Posted October 1, 2014 Share Posted October 1, 2014 Eh plugs aren't that bad unless you have air injection but even so it's easily done in 2 hours working slowly.... Course that's on an 08 spec.B I have no idea what it's like on a flat 6 Legacy. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
kzr750r1 Posted October 1, 2014 Share Posted October 1, 2014 Your right were talking about fredrik94087... Ok, Bring the plugs man... We can figure it out. Link to comment Share on other sites More sharing options...
LGTfoLIFE Posted October 1, 2014 Share Posted October 1, 2014 Would anyone be willing to teach me how to install spark plugs & a crank pulley in my car? I'm getting my car tuned by Travis at snail performance on the oct.10th & I want to have these parts in before my tune. Link to comment Share on other sites More sharing options...
magnusonsubie Posted October 1, 2014 Share Posted October 1, 2014 Crank pulley is easy. Here is a right up I found for the spark plugs. Shouldn't be too hard. I haven't done them on my legacy yet but did them on my old impreza and it wasn't too difficult. Just have to move stuff out of the way. http://legacygt.com/forums/showthread.php/spark-plug-install-instructions-12070.html 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
LegAC_GT Posted October 1, 2014 Author Share Posted October 1, 2014 Were gettin close guys! Only 4 days until it's time for some legacy goodness! Link to comment Share on other sites More sharing options...
