scobaru5 Posted September 8, 2014 Share Posted September 8, 2014 My car randomly stopped starting the other day when it was driving fine the previous night. The car is a 05 LGT wagon and it cranks over but doesn't fire. I hooked up a tactrix cable and It's getting a Crank position signal along with cam but its not firing the injectors and I don't believe its getting spark, I pulled a coil out and grounded the spark plug and I'm getting nothing. I can hear the fuel pump and I'm getting fuel from the pump. any suggestions? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 8, 2014 Share Posted September 8, 2014 Have you checked all the engine grounds ? the two on the bottom of the heads to the chassis and the two below the master brake cylinder. Make sure they are clean and tight. I know on Hondas if the ECU doesn't get a proper signal when you switch the key to ON it will not allow the fuel pump the send fuel. The ECU sends out a 5v test signal, if it doesn't get returned the car won't start. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
scobaru5 Posted September 10, 2014 Author Share Posted September 10, 2014 did more test and the ecu isn't grounding out the injectors to fire Link to comment Share on other sites More sharing options...
