darkwagon Posted September 4, 2014 Share Posted September 4, 2014 I just changed my oil and think I may have over filled slightly... Maybe some over you that are knowledgeable can ease or confirm my worry... The level reads slightly above the full "F", right at the little hole that's above the "f". Do I need to drain a little bit? This is also my very first cycle with RT6. Thanks Matt Link to comment Share on other sites More sharing options...
bluesuby Posted September 4, 2014 Share Posted September 4, 2014 I found the reading on the dipstick isn't always accurate and can be different comparing one side with the other. I put 4.5 quarts in my 2005 LGT with a filter change and ignore the appearance of overfilling. You need to worry more about oil loss and a low reading. Link to comment Share on other sites More sharing options...
Akasa Posted September 4, 2014 Share Posted September 4, 2014 You didn't overfill it much, if at all. You'll burn off the overfill quickly enough. Link to comment Share on other sites More sharing options...
darkwagon Posted September 4, 2014 Author Share Posted September 4, 2014 I found the reading on the dipstick isn't always accurate and can be different comparing one side with the other. I put 4.5 quarts in my 2005 LGT with a filter change and ignore the appearance of overfilling. You need to worry more about oil loss and a low reading. You didn't overfill it much, if at all. You'll burn off the overfill quickly enough. Thanks guys! I searched a bit more and found additional info. Thanks for the peace of mind! Link to comment Share on other sites More sharing options...
boxkita Posted September 10, 2014 Share Posted September 10, 2014 I used to fill above the hole. Figured with forged internals and running high rpms, it would burn off quickly. Even for DD, I kept it a tad overfull for safety. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
