mth412 Posted September 2, 2014 Share Posted September 2, 2014 My 2011 Legacy has greasy deposits, above the top left and top right corners of the grille. The underside of the hood is marked, but the deposits don't appear to be coming from the engine. The oily/greasy black substance appears to concentrate in the corners above the grille, and drip down the exterior metal to the bumper. Anyone else seeing something like this?? Link to comment Share on other sites More sharing options...
OCDetails Posted September 2, 2014 Share Posted September 2, 2014 Have you tried cleaning them off and seeing if they reappear? have they been on the vehicle since you bought it or is this something new? I'd just clean them off and see what happens. If you leave some things on any surface for too long then you risk staining it forever. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
Max Capacity Posted September 8, 2014 Share Posted September 8, 2014 Where do you park the car ? Is it coming from external ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
