MrTris Posted September 3, 2014 Share Posted September 3, 2014 Roughness can be OCVs, which I don't see on the list. . . Add another $180. Link to comment Share on other sites More sharing options...
Redryan98 Posted September 3, 2014 Author Share Posted September 3, 2014 Definitely was thinking about that. I checked them when pulling the old motor apart and they seemed to move just fine. Monitored them with the accessport and both have nearly identical performance. I'll pull them again today just to double check. I was planning to replace them at some point so perhaps I'll just do it now. Link to comment Share on other sites More sharing options...
PhillyWilly Posted September 3, 2014 Share Posted September 3, 2014 Big list. Good luck and keep us posted. I am either about to do something similar or part with the car. Did you just go with another vf40? What are you using to log the Bosch o2? Link to comment Share on other sites More sharing options...
Redryan98 Posted September 4, 2014 Author Share Posted September 4, 2014 Big list. Good luck and keep us posted. I am either about to do something similar or part with the car. Did you just go with another vf40? What are you using to log the Bosch o2? Thanks, will do. I ended up going with a VF52 Not sure what you mean by logging the 02 sensor. I'm viewing the A/F and other gauges through my accessport. I pulled the OCVs and cleaned them today. Didn't seem to help much but its good to know they appear to be working correctly. Big thanks to Dave at Cryo. Based on his suggestions I'm going to focus more on what mechanical issues might cause the roughness and not the tune. I guess I have no choice but to get a boost/vacuum test. What's weird though is that the roughness varies greatly. Sometimes its very noticeable, other times its non existent. Seems like when I get my shift *perfect* I don't notice much if anything. If I'm off at all than its noticeable. What's also strange is that if I'm cruising at, say, 2,000 rpm in second and give it gas, its pretty smooth. If I shift from 1-2, land around 2,000 and accelerate normally its rough. That mean anything to anyone? Link to comment Share on other sites More sharing options...
PhillyWilly Posted September 4, 2014 Share Posted September 4, 2014 Not sure what you mean by logging the 02 sensor. I'm viewing the A/F and other gauges through my accessport. Didn't know what you were using this with? "Bosch Oxygen Sensor $75" I am trying to decide between a Cryo etune (opensource) or a dyno tune. I figure if I need to buy an o2 sensor and AFR gauge then I might as well get a dyno tune. Link to comment Share on other sites More sharing options...
cryo Posted September 4, 2014 Share Posted September 4, 2014 Hello there, Phillywilly- A wideband is not required for a stock injector stage 3 tune, only when the injectors are upgraded does it become a requirement. *obviously it's very useful data either way.. Op- glad I could help with your questions. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
