garygbnj Posted August 29, 2014 Share Posted August 29, 2014 176k-New throttle body 1 yr ago. The throttle body replacement stopped the intermittent stalliing for a while. Started again after about 8 months. Typically occurs (intermittent) after a long (5-8 minutes) at a more or less continuous speed. As I come to a stop the engine stalls. Starts immediately. Have tried cleaner in the tank (no effect), reset the idle (cold engine, disconnect battery, reconnect and allow to idle to normal operating temp). My mechanic is at a loss as to what to do. Any suggestions? Thanks Link to comment Share on other sites More sharing options...
doobaruGT Posted August 29, 2014 Share Posted August 29, 2014 Are the grounds still attached on the bottom rail? Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
garygbnj Posted August 29, 2014 Author Share Posted August 29, 2014 Forgive my lack of knowledge. What grounds on what bottom rail? Thanks Link to comment Share on other sites More sharing options...
doobaruGT Posted August 29, 2014 Share Posted August 29, 2014 There are two ground leads running from the block to the rail. If you still have your splash guard you may have to drop this to see. Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
