Industry Posted August 27, 2014 Share Posted August 27, 2014 Anyone know what size the bolt is that holds the brake line to the front strut? Broke mine off in the old strut and hoping to grab one one on the way home from work. Thanks. Link to comment Share on other sites More sharing options...
Varano14 Posted August 27, 2014 Share Posted August 27, 2014 It was either 11 or 12mm if I remember correctly. Just changed springs last week Link to comment Share on other sites More sharing options...
Max Capacity Posted August 27, 2014 Share Posted August 27, 2014 Brake line, 6mm x 1.00 or 1.25. Maybe 3/4 -1" long. I zip tie will work too. I'm thinking its just the clamp type bracket your talking about ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
lockmedic Posted August 27, 2014 Share Posted August 27, 2014 It's a 12mm hex. Probably 6mm x 1.0 threads. It's kind of hard to find the nice cadmium plated flange head bolts Subaru uses in a hardware store. For that reason I save all the hardware on cars I part out. Subaru techs probably have a drawer full of random bolts in their tool boxes. . . ask nice and they might give you one. Link to comment Share on other sites More sharing options...
Industry Posted August 27, 2014 Author Share Posted August 27, 2014 You guys are awesome. Thanks. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 27, 2014 Share Posted August 27, 2014 When I wanted 3 bolts for my turbo to up pipe to replace the studs. The parts guy gave me a hand full of them. Just use anti-seize compound on the new bolts your putting in. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
