smitty69 Posted August 26, 2014 Share Posted August 26, 2014 I have to have my tranny replaced. I am purchasing a complete used transmission, but I'm not sure if it will require reprogramming. Can anyone comment, as the transmission shop does not have software for this vehicle. Thanks! Link to comment Share on other sites More sharing options...
MrTris Posted August 26, 2014 Share Posted August 26, 2014 Well, you need to replace with the same year. So if yours is an 05, you need to replace with an 05. Not an 06, or an 07, and certainly not an 08-09. Shouldn't require any reprogramming unless your TCU was somehow damaged. The trans should relearn most of its stuff within a few hundred miles - Anything under that, and it'll act funny for awhile. Just takes time for it to learn. Link to comment Share on other sites More sharing options...
smitty69 Posted August 27, 2014 Author Share Posted August 27, 2014 Okay, thanks. Got an '05 tranny with 52K, so should work perfectly. My car, on the other hand, is working on 175K... Link to comment Share on other sites More sharing options...
MrTris Posted August 27, 2014 Share Posted August 27, 2014 Okay, thanks. Got an '05 tranny with 52K, so should work perfectly. My car, on the other hand, is working on 175K... Not bad! I'm at ~150k, with new motor. These trannys aren't known for failing -- What'd you do to yours to send it to its grave? Link to comment Share on other sites More sharing options...
kzr750r1 Posted August 27, 2014 Share Posted August 27, 2014 Tris, were both right behind him on mileage. Motor now Transmission next. Link to comment Share on other sites More sharing options...
MrTris Posted August 27, 2014 Share Posted August 27, 2014 Tris, were both right behind him on mileage. Motor now Transmission next. No. STFU you'll jinx us both. It might be easy to replace a 5EAT, but, finding one that's in good condition for the right price isn't. Link to comment Share on other sites More sharing options...
kzr750r1 Posted August 27, 2014 Share Posted August 27, 2014 LOL I knocked on wood... I'm expecting it though. Just a matter of time and that right pedal. After talking to Hexmod mister last year I'm pretty sure sending mine to him for a rebuild would be the best option. My favorite transmission shop closed down a couple years ago. Link to comment Share on other sites More sharing options...
smitty69 Posted August 27, 2014 Author Share Posted August 27, 2014 Not bad! I'm at ~150k, with new motor. These trannys aren't known for failing -- What'd you do to yours to send it to its grave? I replace my motor at 142 K.. 3 stock turbos third one shot shards of metal into the motor. I don't really know what happened to the transmission area but the guy at the transmission shop told me that these are actually pretty notorious for failing. Link to comment Share on other sites More sharing options...
kzr750r1 Posted August 27, 2014 Share Posted August 27, 2014 ^If you follow the manufacturer regarding fluid flush yeah, I'd believe that. The first pan drop I performed was full of clutch pack debris. There are a few here with more power and or mileage on them. Looking forward to hearing how the swap goes for you. Over all this has been a really nice auto trans for me. Link to comment Share on other sites More sharing options...
smitty69 Posted August 28, 2014 Author Share Posted August 28, 2014 There are a few here with more power and or mileage on them. Looking forward to hearing how the swap goes for you. I've loved driving the car..... but I've had just about everything than can go wrong, go wrong. And yes, I have put several performance mods on it. Started with 3" catless dp and ECU flash. Then STI up-pipe. Blew up a stock turbo and blew end-tanks off stock IC twice, so added Perrin TMIC (awesome product. Double cooling area and SOLID piece of aluminum), Perrin radiator hoses, Cobb turbo heat shield, and a more agressive stage 2.5 map (not that bad, peak psi at 17lb. Although data logs showed times when it would go up to 19...). Blew 2 more turbos, then the motor. When that was replaced at 142K, I also put in a new radiator, timing belt, Megan coilovers all the way around, BNR 16g turbo. Now the transmission. I've fixed just about everything, and NOW I'm planning to sell it? Someone's going to get the newest 175K car around, and with tons of performance mods. Link to comment Share on other sites More sharing options...
SCASEYS Posted August 28, 2014 Share Posted August 28, 2014 Mitch's Auto Parts in your area has 2 in stock under 50K under $900.00 each I donated to LegacyGT.com which allows me to have this nifty signature. If anything SCASEYS posts ever becomes a sticky i'm gonna light this whole place on fire Link to comment Share on other sites More sharing options...
smitty69 Posted August 29, 2014 Author Share Posted August 29, 2014 Mitch's Auto Parts in your area has 2 in stock under 50K under $900.00 each I got one being delivered today. Wish I had known that Tuesday. I paid $1500. $250 of that was shipping from NY. Best I could find in a very short time. Link to comment Share on other sites More sharing options...
smitty69 Posted August 29, 2014 Author Share Posted August 29, 2014 It only has 50200 miles and a 6 month warranty so.... Link to comment Share on other sites More sharing options...
