mkee87 Posted August 24, 2014 Share Posted August 24, 2014 So I hit a big pothole and my front passenger wheel has a lot of negative camber now. Is this something I can adjust myself and if so how? Link to comment Share on other sites More sharing options...
iNVAR Posted August 25, 2014 Share Posted August 25, 2014 If it's that much, you probably bent something, so no. And even if something wasn't bent, adjustments should be made at an alignment shop. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted August 25, 2014 Share Posted August 25, 2014 ^+1. Take it to a reputable suspension shop so they can put it on the rack and see what parts you bent. If you can notice the negative camber just by looking at it, then it's extremely likely something is bent and needs to be replaced. Link to comment Share on other sites More sharing options...
mkee87 Posted September 3, 2014 Author Share Posted September 3, 2014 Got it fixed, had a bent strut and replaced both control arms :/ Link to comment Share on other sites More sharing options...
