steven1955 Posted August 21, 2014 Share Posted August 21, 2014 So I'm replacing the clutch on our 99 OB, and also replacing the very leaky original plastic oil separator plate with a new Dorman metal one. It sure looks like this plate is designed to be used with a gasket, but there was no gasket with the Dorman plate, nor can I find any mention here or on some other Subaru forums about the metal plates needing to be installed with a gasket. I've only found mentions of Permatex Ultra Grey or anaerobic sealants. So help me sleep better at night: Is there supposed to be a gasket? Link to comment Share on other sites More sharing options...
worknlikeadog Posted August 21, 2014 Share Posted August 21, 2014 No gasket just silicone Link to comment Share on other sites More sharing options...
camroncamera Posted August 22, 2014 Share Posted August 22, 2014 Anaerobic sealant, I used grey Dirko when I did mine: http://legacygt.com/forums/picture.php?albumid=796&pictureid=4398 http://legacygt.com/forums/showthread.php/just-purchased-98-lgt-wagon-coolant-positive-hydrocarbons-151027.html?p=3235029#post3235029 Link to comment Share on other sites More sharing options...
96legacyls Posted August 22, 2014 Share Posted August 22, 2014 yea just use rtv silicone. just put nice bead all the way around it and the bolt holes let it sit about 5-10 min so it starts to dry a lil bit and then slap it on n and barely tighten enough to just smoosh the silicone a lil bit wipe away extra n let it sit for couple hours and then tighten it down for good. make sure surface is clean n oil free. Link to comment Share on other sites More sharing options...
steven1955 Posted August 23, 2014 Author Share Posted August 23, 2014 Thanks for your answers. I had to ask because it looked like the design called for a gasket. I used Permatex Ultra Grey, and while I was at it I also sealed the wrist pin access cover and both of the black plastic box things on the heads that are also called oil separators. They were leaking almost as badly as the plastic oil separator plate behind the flywheel.. Link to comment Share on other sites More sharing options...
