Vmax540 Posted August 19, 2014 Share Posted August 19, 2014 2005 GT with new Invidia Up pipe, Catless Down pipe, GrimmSpeed Cross pipe and Borla cat back exhaust. I'm looking for advise on what all to wrap and the pros/cons of wrapping the manifold, up pipe, header, Down pipe, cross over pipe ? Any suggestion on what wrap to use would be appreciated Thanks, Chuck Link to comment Share on other sites More sharing options...
chato Posted August 19, 2014 Share Posted August 19, 2014 I wrapped the up and first couple feet of the down to keep heat down around the TMIC. folks that wrap their headers complain of deterioration, although that's usually with aftermarket parts. Link to comment Share on other sites More sharing options...
Merc6 Posted August 19, 2014 Share Posted August 19, 2014 I wrapped the up and first couple feet of the down to keep heat down around the TMIC. folks that wrap their headers complain of deterioration, although that's usually with aftermarket parts. You wrapped OEM headers, up and down? 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Mr.Goodbarf Posted August 19, 2014 Share Posted August 19, 2014 I wrapped the up(completely)/down(just past the first bend) . FWIW the stock dp had a heat shield protecting the passenger side cv boot, doesnt hurt to keep heat off of it Link to comment Share on other sites More sharing options...
Max Capacity Posted August 19, 2014 Share Posted August 19, 2014 Yep pretty much what I did, ^ I also did the exhaust manifold by the oil filter, because the stock heat shield rusted off. I think there are pictures in my click here link. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SpecBot Posted August 19, 2014 Share Posted August 19, 2014 After I did the VF52 upgrade, I wrapped portions of the wiring harness (that ran near the turbo area) with self - fusing silicone electrical tape that is insulating up to 500 degrees (intermittent) and also creates a water proof seal. The oem plastic sheathing on the harness seemed to be kind of weak for heat insulation. Link to comment Share on other sites More sharing options...
snow05gtRI Posted August 20, 2014 Share Posted August 20, 2014 i wrapped my original Grimmspeed crossover pipe and I'm pretty sure it accelerated the flex joint failing. Had a terrible leak out of the flex joint after maybe 2yrs or less of use. They replaced it for me, though. Can't say enough about their customer service. So, I do not recommend wrapping the crossover. Or, if you do, don't wrap the flex joint. Link to comment Share on other sites More sharing options...
Tehnation Posted August 20, 2014 Share Posted August 20, 2014 Flex joint? You mean up pipe? I thought crossover pipe was solid pipe? Link to comment Share on other sites More sharing options...
snow05gtRI Posted August 20, 2014 Share Posted August 20, 2014 Grimmspeed crossover has a flex. edit: the OEM has one too, I'm pretty sure. Just a weird one. Link to comment Share on other sites More sharing options...
