SohcIt2me Posted August 17, 2014 Share Posted August 17, 2014 Hi I have a 2008 subaru legacy limited 2.5 sohc, and found my oil temperature sensor broken after pulling a p0198 code from my obd2. Literally broken, snapped in half, dunno how. I tried contacting multiple dealerships in my area but they keep saying it must be a coolant temp sensor and that's all they can find. I pulled the part and there's definitely oil on the sensor. It's located next to the oil pressure sensor and oil pressure switch. If anyone knows I'd appreciate the help cuz I'm tired of a talking to dealerships that don't know. Link to comment Share on other sites More sharing options...
Brian3676 Posted August 17, 2014 Share Posted August 17, 2014 I did not know those cars had oil temp sensors. Can you post a picture? Link to comment Share on other sites More sharing options...
SohcIt2me Posted August 18, 2014 Author Share Posted August 18, 2014 The picture of the broken part is the actual part that I pulled. It looks exactly like a coolant temp sensor and that's whats currently in place of it right now since the guy at the dealership parts counter insisted that's what it was. The only thing is that i know the coolant temp sensor is up in the front of the engine and that was pulled towards the back where I believe the oil pressure sensor and vvl oil pressure switch is? Plus it had oil on it not coolant. If you or anyone else can help me with the part number I'd appreciate it cuz I'm not too comfortable knowing a coolant temp sensor is in that spot. Link to comment Share on other sites More sharing options...
SohcIt2me Posted August 18, 2014 Author Share Posted August 18, 2014 I keep looking it up and even called soa to verify. 22630AA17A seems to be part, so I figure it's interchangeable. Most commonly listed as coolant temp sensor, but also called sen ay-temp sensor. Please correct me if my I'm wrong. Seriously. Hopefully This will save someone a headache down the road. Link to comment Share on other sites More sharing options...
boxman Posted August 18, 2014 Share Posted August 18, 2014 A temp sender is a temp sender is a temp sender, as long as it's sending the correct/expected resistance values upstream. Link to comment Share on other sites More sharing options...
Underdog Posted August 18, 2014 Share Posted August 18, 2014 If you want to post or PM your VIN I can double check the P/N against my Subaru OEM catalog. The Crimson Dynamo Link to comment Share on other sites More sharing options...
SohcIt2me Posted August 19, 2014 Author Share Posted August 19, 2014 This is from the vacation pics I downloaded from here: http://legacygt.com/forums/showthread.php/2010-vacation-pics-137900p3.html Funny thing is now my car is pulling a P0118 code: coolant temp sensor Link to comment Share on other sites More sharing options...
Underdog Posted August 19, 2014 Share Posted August 19, 2014 22630AA17A is the correct P/N. The gasket is 803912040. http://imageshack.com/a/img746/5224/nmt7CN.jpg The Crimson Dynamo Link to comment Share on other sites More sharing options...
Max Capacity Posted August 19, 2014 Share Posted August 19, 2014 That's for a 2.5i correct ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Underdog Posted August 19, 2014 Share Posted August 19, 2014 Correct - this particular VIN is an October 2007 build, but the P/N cross-references to all '05-'09 Legacy 2.5 non-turbo SOHC motors. The Crimson Dynamo Link to comment Share on other sites More sharing options...
SohcIt2me Posted August 19, 2014 Author Share Posted August 19, 2014 Thanks for checking. I kept wondering what if it isn't..... Now i just gotta change my coolant temp sensor (on water pipe) weirdly the exact same part number (subaru must use them as general liquid temp sensors or something) to get my main fan to stop running full blast. Link to comment Share on other sites More sharing options...
Chulew Posted March 2, 2015 Share Posted March 2, 2015 I snapped my oil temp sensor when trying to separate bell housing for clutch job. Any risk of driving without this feedback (sensor is still screwed in of course). Link to comment Share on other sites More sharing options...
