T_Altland27 Posted August 16, 2014 Share Posted August 16, 2014 Quick question I recently installed epic springs about 3 weeks ago now after all done got it all aligned I took notice the other day my passenger side front is a half inch higher then my driver front I measured it in my garage on a flat even floor its even noticeable by just looking at both sides nothing is binding so Idk what else it could be to sit a half inch higher can anyone give me any hints as to what is causing this? Link to comment Share on other sites More sharing options...
boxman Posted August 16, 2014 Share Posted August 16, 2014 Top spring seat installed incorrectly? The drain holes have to be toward the outside rather than toward the engine bay. Link to comment Share on other sites More sharing options...
T_Altland27 Posted August 16, 2014 Author Share Posted August 16, 2014 Ok thanks !! Thats won't cause no problem though as far as ruining the spring will it cause its been on there for a good two weeks Link to comment Share on other sites More sharing options...
T_Altland27 Posted August 16, 2014 Author Share Posted August 16, 2014 And where are the drain holes located? I can't recall when I installed them at all Link to comment Share on other sites More sharing options...
boxman Posted August 16, 2014 Share Posted August 16, 2014 Good pics and instructions found in this thread; http://legacygt.com/forums/showthread.php/koni-shock-strut-epic-engineering-spring-install-145744.html Link to comment Share on other sites More sharing options...
T_Altland27 Posted August 17, 2014 Author Share Posted August 17, 2014 Ok thanks a lot for that link it helped alot Link to comment Share on other sites More sharing options...
derp Posted August 17, 2014 Share Posted August 17, 2014 I'm having the same problem with my epic springs, and i've checked and rechecked the orientation of everything multiple times. I could suck start a snow blower. Link to comment Share on other sites More sharing options...
T_Altland27 Posted August 17, 2014 Author Share Posted August 17, 2014 I just looked and both drain holes on the front are facing away from the engine bay so now I'm completely lost as to why my passenger side front is a half inch higher Link to comment Share on other sites More sharing options...
derp Posted August 17, 2014 Share Posted August 17, 2014 even went so far as to take apart the front spring/struts, and double check everything, still have the issue. when i get home, the car will likely get coils, or bilsteins and a different brand of spring. I could suck start a snow blower. Link to comment Share on other sites More sharing options...
T_Altland27 Posted August 17, 2014 Author Share Posted August 17, 2014 I can't afford new springs as to I just got the epics not even a month ago I already made an email to epic about it I guess I'll have to see what they have to say Link to comment Share on other sites More sharing options...
Rester5350 Posted August 18, 2014 Share Posted August 18, 2014 Could the top hats be worn unevenly? Link to comment Share on other sites More sharing options...
T_Altland27 Posted August 18, 2014 Author Share Posted August 18, 2014 Its possible but the car only has 34 k miles on it Link to comment Share on other sites More sharing options...
derp Posted August 18, 2014 Share Posted August 18, 2014 Could the top hats be worn unevenly? doubtful, i bought them brand new, oem parts from the dealership, in september. I could suck start a snow blower. Link to comment Share on other sites More sharing options...
T_Altland27 Posted August 19, 2014 Author Share Posted August 19, 2014 In just measure tonight and its now at a quarter of an inch I'm coming to the conclusion that there getting broke in now but I'm going to keep checking periodically reason why I think that is I put them on got it aligned the next day and my parents were at of town so my car sat in the garage for almost two weeks since then I put about 100 or so miles on it Link to comment Share on other sites More sharing options...
boxman Posted August 19, 2014 Share Posted August 19, 2014 New springs take a few hundred miles to settle in. Link to comment Share on other sites More sharing options...
T_Altland27 Posted August 19, 2014 Author Share Posted August 19, 2014 Then yeah that what I think it is.then but like I said I'll check weekly though Link to comment Share on other sites More sharing options...
derp Posted August 19, 2014 Share Posted August 19, 2014 i'm at probably 10k on mine, still uneven. I could suck start a snow blower. Link to comment Share on other sites More sharing options...
boxman Posted August 19, 2014 Share Posted August 19, 2014 i'm at probably 10k on mine, still uneven. That's not normal. Possibly a faulty heat treat or stress relief process. I've seen this several time in the Jeep world where new springs would settle in differently than expected, but that's with leaf springs...similar techniques for heat treat and stress relief so I'd expect similar issues. Link to comment Share on other sites More sharing options...
