LegAC_GT Posted June 27, 2014 Share Posted June 27, 2014 Hey guys my starters beginning to take a dump. Need a temporary used one until my supplier gets it in. Link to comment Share on other sites More sharing options...
FJuan Posted June 27, 2014 Share Posted June 27, 2014 What is the starter doing? If it's sticking, you can take the upper housing off and lube up the shaft and gears. The OEM starters have know to stick due to it drying up. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
LegAC_GT Posted June 27, 2014 Author Share Posted June 27, 2014 Not sure if stuck, but it doesnt click or make any noise, once i tap it with a brass punch and hammer it starts to crank. Link to comment Share on other sites More sharing options...
FJuan Posted June 27, 2014 Share Posted June 27, 2014 That almost sounds like it's stuck, if not the solenoid contacts are dead. An easy way to tell is pull it off and try to move the top gear up/down, that will determine if the shaft and gears are dry. Maybe a good cleaning and lube job will help, if not, time for a new/rebuilt one. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
compsurge Posted June 27, 2014 Share Posted June 27, 2014 Take it apart, clean it, and lube it. I have 135k on mine and I need to clean and grease it yearly to prevent it from sticking. Link to comment Share on other sites More sharing options...
LegAC_GT Posted June 27, 2014 Author Share Posted June 27, 2014 I'm replacing it regardless, just needed something to hold me through for the weekend. Good to know about the sticking Link to comment Share on other sites More sharing options...
chato Posted June 30, 2014 Share Posted June 30, 2014 if you change your mind about the rebuild. takes about 45 mins longer than a straight swap. http://legacygt.com/forums/showthread.php/diy-starter-repair-remove-disassemble-grease-reinstall-w-pics-218329.html Link to comment Share on other sites More sharing options...
