Rear panel removable?
aziankingz
Hi All,
Just wondering if anyone knows if the rear panel where I circled in the pic is removable? I ask because rust is forming in between that panel and the fender on both sides. Has anyone tried removing this and if so, how? Also, what is the proper name for that piece?
Thanks!
that part i believe is removable, sadly the part above and to the right of it is welded to the car, sadly that is where someone kicked/chipped the paint on mine :(
Its part of the body so you will need a service manual to do it properly and most likely there will be some seals/trim you will have to replace unless your really careful doing it.
