Shudder in steering wheel when braking, not in brake pedal
nixican
Ive been assuming that I have build up on my front rotors because of a nasty shudder I get when braking. The rotors are fairly new, (purchased in Oct 2012) and they dont see much more than street driving. I will be replacing the rotors and pads at all four corners in the next week or so just in case its more than just build up but Im wondering if brakes are my only issue (or my issue at all). I just realized that I feel the shudder in my steering wheel only, I cant seem to notice any shudder in the pedal at all. Is that normal? Is it indicative of a larger problem than just brakes? There is no steering wheel shudder driving, only on braking.
Thanks for your input!
Before just replacing stuff, try to re-bed your brakes and see if that helps. That could help determine if it's just deposits or something else. If the deposits are bad enough, you can try having the rotors turned provided there is enough material left.
I have the same problem and it's been on BOTH my Lgts. The caliper is starting to stick and gives uneven pressure from left to right causing the wheels to want to turn the car. Alignment says no and they fight back and forth. I'll link my thread where someone posted a refurb kit. Have yet to do it to this car but it fixed it in a hurry when i replaced my seized caliper last time.
We are starting to see more and more bad calipers lately on this vintage of vehicle here in the NY/NJ area due to the salt, time and road conditions here.
-Mike Paisan
http://www.pbase.com/paisan/image/153798190.jpg
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
Do you replace with new, or rebuilt, or would the refurb kit for $15 be sufficient?
Whats the next 'best' upgrade for a set of calipers if you have to replace them? I think the SS lines are required to move up to anything with 2 POT right?
We generally will just replace caliper with a new or rebuilt one. It doesn't pay to rebuild it ourselves by the time we charge the customer labor they can have a completely new one. They are relatively inexpensive and worth the money.
These calipers are 2-pot/1-pot. I would go to SS lines before going to 4-pot/2-pot setup.
To be honest unless you are racing your LGT the brakes on this car are plenty big for street duty and even track duty with the proper pads.
I see you are in NJ, if you wanted us to replace your calipers or anything just ask.
-Mike Paisan
Ill have see what the rebuild looks like. This is just my DD..
Im all for just having you do it, you did my clutch on my last LGT..
but if I can get away with a DIY rebuild for $40...
  • 2 weeks later...
Thanks for the info Canon. I get the same pedal feel (not as much shudder on heavy or light load). Now I need to determine what the cause is.
The first thing to do is rebed the brakes its free and may work.
Do 4 or 5 almost stops from 50mph, stand on the brakes hard just short of lock up. Don't stop the car, repeat 4 more times, drive the car for a mile without touching the brakes.
Years ago lots of had this issue, it was the crappy OEM pads, we changed to Hawk HPS or other pads and the issue stopped.
Engine Build - Click Here
So, I replaced the pads, front and rear and did an extensive bed in process. As part of the pad changeout I also regreased the guide pins. I still get some shudder but its almost always on light to medium pedal pressure. This is also intermitant. It happens more often than not, but its still not every single time. This tells me that its not warped rotors but something in the caliper. Does this sound about right?
What ever I did seems to have helped a bit but Im still not satisfied yet.
No I did not. I wanted to try the bed in first. But like I said, it is not something that happens all the time, it is intermittent. Wouldn't that eliminate a warped rotor issue? The rotors are not super old either. Centric premiums.
