covertrussian Posted April 25, 2014 Share Posted April 25, 2014 My stock mirror was starting starting to fail, I saw this as a perfect opportunity to upgrade to a Homelink mirror. This is a very simple upgrade if you find the mirror with the same mounting, for me an 08 STI mirror (Will try to get part number) worked wonderfully. http://legacygt.com/forums/attachment.php?attachmentid=220944&stc=1&d=1449587271 Once removed it revealed the mount, Subaru has a bunch of different mounts, hopefully the 08 STI mirror I got fits. http://legacygt.com/forums/attachment.php?attachmentid=220945&stc=1&d=1449587271 Two mirrors side by side http://legacygt.com/forums/attachment.php?attachmentid=220946&stc=1&d=1449587288 http://legacygt.com/forums/attachment.php?attachmentid=220947&stc=1&d=1449587288 Once I removed the adapter that the STI mirror came with, underneath was the same mount! http://legacygt.com/forums/attachment.php?attachmentid=220948&stc=1&d=1449587315 Bolted right up http://legacygt.com/forums/attachment.php?attachmentid=220949&stc=1&d=1449587315 Next was needing to replace the connector since they are different. http://legacygt.com/forums/attachment.php?attachmentid=220950&stc=1&d=1449587353 It's the plug with green, blue and black wires http://legacygt.com/forums/attachment.php?attachmentid=220951&stc=1&d=1449587353 New wire was $15 at the dealership (cheaper then people's custom made ones on ebay). Part number: H501SAG030 http://legacygt.com/forums/attachment.php?attachmentid=220952&stc=1&d=1449587375 Plug it up and try it out http://legacygt.com/forums/attachment.php?attachmentid=220953&stc=1&d=1449587375 http://legacygt.com/forums/attachment.php?attachmentid=220954&stc=1&d=1449587464 After that I had to set the zone to my location and force it into Config mode (press and hold the button for 9 seconds), then drive a car in a 3 circles. For more instructions see: http://www.scoobymods.com/showpost.php?p=33805&postcount=2 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
theflystyle Posted April 25, 2014 Share Posted April 25, 2014 Thanks for the writeup and pictures. Link to comment Share on other sites More sharing options...
Drift Motion Posted April 25, 2014 Share Posted April 25, 2014 You don't need Subaru mirror I've ran Hyundai minivan one, and Hyundai Genesis mirror. Both have the right plugs on both side, GNTX 453? You can buy those OEM cables online for about $7 shipped http://www.wembleysells.com/mirrortech/GentexHomelinkMirrorComparison.htm Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted December 8, 2015 Moderators Share Posted December 8, 2015 Moved to interior/exterior section. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
SBT Posted December 8, 2015 Share Posted December 8, 2015 Thank you for the writeup. Loaded the pics to the site's server in case the linked pics goes down. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
covertrussian Posted December 8, 2015 Author Share Posted December 8, 2015 Thank you for the writeup. Loaded the pics to the site's server in case the linked pics goes down. Thanks for doing that! I need to go through my other How To's and do the same incase something happens to my PB account and to help reduce my Photobucket bandwidth usage 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
NSFW Posted April 13, 2016 Share Posted April 13, 2016 How do you open up the dome light assembly? I put in LED lights up there years ago but now I can't figure out how I did it. Link to comment Share on other sites More sharing options...
covertrussian Posted April 13, 2016 Author Share Posted April 13, 2016 From what I remember you just pull it down on one of the sides and it should come off. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
EPIC Stratton Posted June 15, 2016 Share Posted June 15, 2016 Anyone know if you can wire up one of these in a model that didn't come equipped with a autodimming mirror? That is, is the plug still up there if I bought the mirror and wire mentioned in the write up. Link to comment Share on other sites More sharing options...
